Originally Posted by
TheBlubbs
So, how are you supposed to clearly 'hear' 16hz sounds? That is below the range of the human ear. haha. Obviously they could be felt, but I don't understand how you could make the former claim.
i believe he said "heard and felt" if you're referring to post #1
when you step on a 32' pedal stop of a pipe organ which is 16hz if it's the lowest note of a 32' rank, you can both feel the fundamental tone and hear the upper harmonics of the note
it also depends on the "type" of 32' rank you're talking about (Contra Bourdon 32, Contra Principal 32, Contra Violone 32, Contra Bombarde 32 etc.)
some have a lot of fundamental and very little harmonic development, some have both fundamental and good harmonic development, some have little fundamental and plenty of harmonics
and some like the loud reeds (Contra Bombarde 32) with plenty of building-shaking fundamental and plenty of harmonics, both in tune and out of tune
technically, if you're sitting in an anechoic chamber with a 16hz sine wave playing, chances are you will "hear" nothing
but organ pipes are a bit different
*some of the rank info copied from this site:
http://www.chisham.com/tips/bbs/feb2...es/123408.html
