AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Buzzing Sound When DVD Player Connected
post #1 of 3
Hi!
I got a new LCD TV last week and it works fine. No problems so far.
Now when I hook up my DVD Player (Samsung) and power it on I get a loud buzzing from the TV speaker. I checked all the connections (5 cables) plus the plug into the power bar and everything seems fine.
Does anyone know what would be causing the buzzing?
How do I fix it?
James
post #2 of 3
This is the first time it's happening. Was fine connected to my last TV.
Another thing. Do I have this connected properly?
Cable box to TV using Component (5 cables)
DVD Player to TV using Component (5 cables)
On my old setup I had 2 extra connections:
A cable (like the cable company's one) from the DVD Player to the TV.
And an antenna wire (like a conponent wire) from the DVD player to the TV antenna on the TV. Don't see any antenna input on my new LCD one though.
I am not sure about the connections though. When Rogers came to switch the cable box to my TV he just pulled everything out quick so am not sure where everything went.
James
post #3 of 3
O.K. Never mind. Figured it out.
James
  Back to Forum: DVD Players (Standard Def)
