AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › Possible Overheating Solution on the Horizon
post #1 of 21
This isn't guaranteed to come out, but I'm still excited about this. I've been looking for a new case to come out for ages!
http://www.bit-tech.net/news/2008/01...x_360_owners/1
post #2 of 21
MS added a heatsink to the GPU on the new systems plus the new chips run cooler.
post #3 of 21
post #4 of 21
That doesn't change the fact that there are still problems. Also, every 360 out there isn't a 65 nm. (in reference to flood222's statement)
post #5 of 21
yeah good point. But its covered under warranty.
Upgrading360 or warranty replacement are better options that the case IMO. Although the case does have the geek factor.
post #6 of 21
That's part of the reason I want one.
post #7 of 21
Yea but there's still no evidence that that heatsink and the die-shrink on the CPU are enough to eliminate overheating issues. Plus MS's RRoD warranty is worthless, you get to wait a month for the replacement process then get a system that will brick sometime between immediately after you get it back and 3 months later.
The case mod would probably quiet the fans quite a bit too, and as you said: geek factor.
post #8 of 21
I'm at 4 months with my replacement. I must be special.
post #9 of 21
Waiting for a replacement does indeed suck.
That case is no guarentee either though. Then you'll have voided your warranty and be out the $$$ for the 360.
post #10 of 21
Ok, so I exaggerated a bit but I've heard of too many people saying their on their 3rd 360 to trust the RRoD warranty. Including a few people I know who have gotten their refurbs, turned them on, and been staring the RRoD in the face.
post #11 of 21
They didn't list a price but generally speaking Lian-Li cases are expensive. If you're willing to break your warranty (which this would do) there are much cheaper and effective alternatives.
post #12 of 21
Yea but if you're willing to do the case mod you probably won't mind doing the x-clamp fix and replacing the thermal paste if your 360 does brick.
post #13 of 21
I think moving the DVD drive off the top of the GPU heatsink alone would make huge strides in longevity.
post #14 of 21
The solution has always been here and I like to think every once in a while I really nail it.
It's called a mini-fridge. Top shelf you place the 360, drill a whole out the back for cables and silicoln it tight. Beer on the bottom shelf. What you get is a cool 360 and a quiet 360 and face it, you always wanted a mini-fridge any way! FTW, thank you very much. lol but a serious lol
post #15 of 21
Bingo, takes longer to read this thread than it does to do the x-clamp fix. As far as all the talk about the 65nm chips, the problem is not with CPU, it is with the GPU. The GPU gets hot and the lead-free solder begins to melt, which allows the chip to move, causing the red rings. If you can do some research and turn a screwdriver you can do the x-clamp fix and thermal paste in no time flat.
post #16 of 21
I have an out of coverage X360 I'd like to try with this.
post #17 of 21
I gotta agree with posters here....Who exactly is buying this....if you are willing to void your warranty, you can use any old PC case and just drill a couple of mounting holes..hell just take the top cover off the case....there's a host of potential options.
I don't get it: Would you rather spend $150 on a Lian Li (they aren't cheap) case or just pay $120 or so to get your Xbox fixed out of warranty??? My original replacement is running just dandy for 1 1/2 years now.....
More Confusion if you read the article: "thanks to the case you can now upgrade the Hard Drive"...huh?! Unless of course they are talking about running your 360 hacked. :P
I have no idea who would buy this thing.
post #18 of 21
Even a 360 with hacked firmware will not allow you to upgrade your harddive, these guys obviously know nothing about the 360.
post #19 of 21
There is no way the solder melts. The melting point for most commonly used lead-free solders is around 200 deg C. The chip would be damaged long before then. I don't doubt there are mechanical problems related to board flexing that end up breaking connections or causing poor contacts, but it is definitely not solder melting.
post #20 of 21
It's called condensation, it will ruin your 360.
post #21 of 21
I try not to think about the next RROD. I'm hoping my refurb hangs in there until the new units have a long track-record without failures, then I'll get a new one and demote this box to an emergency spare. But that case would be nice if I could ship my unit to an Approved Installer and get back something that would still have a warranty. I wonder how much Microsoft would want to authorize a company willing to do that?...
  Back to Forum: Xbox Area
