Hi
I'm learning that most screens top out a little past a 120", how does screen paint stack up? I am currently 'test' projecting and area 170" diag 16:9 I believe. and I want a good compromise b/w brightness/contrast and size soooo... I'm getting confused b/w the throw distance, and how that will be counteracted by the screen material's gain level. So could I get a bigger picture (dimmer) and then regain some of that light level by getting a better gain on the screen?
Right now I'm just trying to see how big I can really get the picture with my new benq w1000 and watched Appleseed last night at 170" diagonal ( believe that is at the 16:9 ratio - filled up the whole available area - I have a pretty long room, 40 or so by 14). My friend says I may be getting a little ridiculous and should stick around 120" diag. The projected light level seemed ok to me though considering I was using a standard white wall (at night w/ lights off) and we sit back far enough to really enjoy the bigger screen size (we aren't having to look from side to side). Could I realistically get an image that size to really "pop" with a good screen? Its a really good projector from the research I've done here. I'm also planning on following some other advice on this forum and paint the ceiling near the screen flat black. What are the general recommendations on size? I plan on mostly viewing movies at night with the occasional 'super bowl' gathering (moderately back lit). Would the screen paint be adequate for a noob that might not know the difference?
So I guess there are multiple questions packed in here. Feel free to educate me on any one of them, or just let me know if I am beyond help
Mike
Mike
Being new to all this, who makes the model C? That's also very helpful in the decision process to know about the seem not being too visible.
