AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › DCH3416 backup to VCR or DVD-Recorder?
post #1 of 6
I did some searching, but couldn't find the answer to this question.
Does the Comcast DCH3416 allow backing up of recorded shows to VCRs or DVD-recorders, or to PCs?
Eph
post #2 of 6
Any thoughts?
Thanks again,
Eph
post #3 of 6
You should be able to if you have a dvd burner or vcr in line with the box. You would just have to watch and record at the same it.
post #4 of 6
Thanks - but can you transfer the prerecorded shows to VCR or DVD, or can you only transfer things you are watching live?
Also, what outputs would you use on this box?
Thanks again!
post #5 of 6
pre recorded will work. The rf output on that box converts the output to analog, so you could do any program you record, I wouldn't do hd stuff though.
post #6 of 6
