I'm at my wits end, and am about 2 steps away from shattering my remote against a wall. UGH!
I had a Harmony 890 for about a year, and it worked *perfectly*. I loved it--it never gave me any problems. That all changed about two weeks ago.
All of a sudden I had to be about 6 feet from the extender for it to work, and it was sketchy at that. I thought the remote had gone bad, so I bought another. It seemed to do the same thing, so I swapped it out. This one is doing the same thing. I have paired, unpaired, updated, firmware updated, connected z-wave devices and so-on... every trick in the book--and it still won't work right. I'll press buttons here and there with no response, or sometimes it will seem to do nothing and voila! It will do all 15 button presses at once and get everything garbled up. Sometimes it will take a command from 20 feet, and then won't execute another command at that distance for 15 minutes.
For the life of me I can't figure this out. As far as I know nothing has changed. I do have an RF mouse and keyboard, so I unplugged those in case they were causing interference... no dice. Does anyone have any ideas what to do??? I'm trying to operate my components no more than 15 feet away... WELL within the range of this thing, and as mentioned before, my old remote did it for a year flawlessly. Should I go into the website and throw away all of my current setups and start from scratch? That's the ONLY thing I haven't done. Any suggestions would be greatly appreciated.
, that I was flooding the IR receiver on the Snazio. I had to move the IR eye AWAY from the proper spot just in front off the IR receiver.
