UPDATE 06/20/2008: ControlCAL v1.41 Beta 3 is now available! Formerly SSPC - Simple Serial Projector Control (and CalBOY for 1 Day).
http://www.ControlCAL.com
ControlCAL is an easy Control and Calibration Application for Displays supporting a Serial/RS232 interface. ControlCAL will allow you to send any available commands to any Display that allows RS232 control (in 'Advance' Mode). You may need the document that shows the RS232 codes for your specific Display model.
Using ControlCAL's One Page Calibration Screen will allow you easy access to your Display's Calibration Controls... No need to fumble through the Display's Menu with its Remote Control.
With Third party Calibration Applications that control Colorimeters and/or Spectroradiometers and support ControlCAL's API (under development), the entire Display Calibration Process can be automated.
03/26/2008 UPDATE: There is now a Dedicated Forum Thread for the Kuro 8G Pioneer ISF C3 Display Profile(s) HERE
Suggestions and Feedback Welcome!
MS Windows XP/Vista+ Supported. The .NET Framework is not required but DirectX is.
IMPORTANT INFORMATION AND TIPS FOR MITSUBISHI MODELS IS AVAILABLE IN POST #11.
Help with the options in Edit/Create mode will be in Posts #2-#3 in this thread....
DOWNLOAD HERE:
Download ControlCAL v1.41 Beta 3 or Get More Information
In Development:
v1.41
Dedicated Gamma Controls, 8 Button Controls (2 Additional Buttons in ISFccc Mode), 6 Additional Slider Controls (#13-#18) and Special Pioneer ISFccc Mode* including a matching Display Profile* for Pioneer 8th Generation Elite Kuros (North American and European Models).
*Pioneer ISFccc Modes and Display Profiles are Locked Profiles.
Released Versions:
v1.4 RC1 - 03/05/2008
+NEW ControlCAL Display Profile File Format (.cdp extension).
+Create/Edit/View/Save ControlCAL Display Profiles Option.
+Load Display Profiles created by others.
+You can now toggle between ASCII and HEX Input Modes in the ControlCAL Terminal Window (Advance Mode).
+Internal Serial Command Format Support for many Manufacturers including BenQ, Epson, JVC, Panasonic, Pioneer, Mitsubishi, Sanyo, Sony (including Sony Checksum), Sharp and more....
+Internal Support for Mitsubishi HC Series Projectors - Profile can be used as a starting point for Creating a Profile for your Display.
+Many Internal Code Changes...
+More info Coming Soon......
*v1.4 RC1 is a Time Limited Version and will expire on May 31, 2008.
v1.3 - 02/07/2008
+Name Changed to ControlCAL.
+MS Vista Now Supported.
+Several Internal Code Optimizations.
+Fixed Xon/Xoff Flow Control Bug.
+Added 'Donate' Menu Option (Donate via PayPal for ControlCAL's Development).
v1.2 - 01/27/2008
+Added Internal PQ Calibration Control Support for Mitsubishi Projectors (tested on HC3000, HC4900*).
+Added Serial Communication Error Handling
+Several Internal Code Changes.
*HC1500, HC5000 and HC6000 should work as well (and other Mitsubishi Models or Displays that support their Serial Codes).
v1.1 - 01/23/2008
+Added ability to change Port and Parameters.
+Terminal Window is now optional (Advance Mode).
+Polished up the interface.
+Interface ready for Projector specific Control/Calibration Page.
More info in POST #10
v1.0 - 01/14/2008
Original Release.
Here are a few screen shots:
New v1.4 Display Profile Edit/View Option:
"One Page Calibration Screen" for Mitsubishi Projectors (HC1500/HC3000/HC4900/HC5000/HC6000):
ControlCAL Terminal Window (Advance Mode):
Advance Mode Port Monitoring and Send Confirmation not available in Locked Display Profiles.
DOWNLOAD HERE:
In Development:
v1.41
Released Versions:
v1.3 - 02/07/2008
v1.2 - 01/27/2008
v1.1 - 01/23/2008
v1.0 - 01/14/2008
Original Release.
