AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Simple Serial Projector Control for Mits HC3000, HC4900 or any Projector with a RS232
Simple Serial Projector Control for Mits HC3000, HC4900 or any Projector with a RS232 - Page 2
post #31 of 80
Hey Shawn...thank you for this app. It looks like exactly what I need.
Quick question...
Will it work over USB or only the serial interface?
John
post #32 of 80
could I change the wheel speed of my HC3100 with this thing ?
switching between 4X and 5X from windows would be pretty sweet
I've found the RS232 list for the HC900 :
http://www.devicemanuals.com/guide/P...kRZeE5qUT.html
but not for the HC3100
post #33 of 80
Quick question...
John
For USB to Serial adapters, it should work (see my posts about wireless serial adapters on page 1, specifically the USB model) though there are some adapters/driver combos that will not work with standard serial applications.
Currently, ControlCAL will only work with ports COM1-COM9, so make sure you can assign the USB in that range.
If you have any problems, post here..
If switching from 4X to 5X is supported via the Projector's serial port, then yes. ControlCAL does allow unrestricted access to your display, though you need to know the Serial Commands for your specific Display. The next version of ControlCAL will allow Users to create their own Display Profiles, save them and share them with others.
-Shawn
post #34 of 80
yeah that's the thing, I've got no idea what the command is
post #35 of 80
Here's an updated Pic of Profile Edit/View Mode... Gamma Controls are currently disabled!
-Shawn
post #36 of 80
Where does one get the 8 pin serial connector for a Mitsu HC pj? Is it mini din?
mech
post #37 of 80
mech
The cable comes in the box with the projector. You could buy one or make your own...
post #38 of 80
No kidding?!?! I haven't looked at anything other than the remote and pj in well over a year! Looks like I'll have to dig around for it! Thanks Shawn!
mech
post #39 of 80
indeed, I've just checked. I've got the cable in the pj box
so basically I just plug this cable on a COM port and the pj, and I can calibrate my HC3100 w/o using the remote ?
I need to reach the R/G/B contrast/brightness and general br/cr settings
post #40 of 80
Correct. Once you start ControlCAL, you may need to press F12 in ControlCAL's Terminal Window (Advance Mode) which sends only a Carriage Return to initiate communication. The 'Refresh' Button will read the current settings from the Projector.
"w/o using the remote"
That is the idea behind ControlCAL's "One Page Calibration Screen"... (No fumbling through the menu with the remote)....
-Shawn
post #41 of 80
Shawn,
Thanks a ton! I found my cable and intend to try this out soon! I'll let you know how it turns out for me.
mech
post #42 of 80
Are you going to be able to lick the "high bright" locked settings deeloo?
post #43 of 80
Wondering the same thing
post #44 of 80
ControlCAL v1.4 RC1 is Now Available!
Download Link is available in Post #1.
Help with the options in Edit/Create mode will be in Posts #2-#3 in this thread....
I'll be posting more information soon concerning the options available when creating and editing ControlCAL Display Profiles....
v1.4 RC1 - 03/05/2008
+NEW ControlCAL Display Profile File Format (.cdp extension).
+Create/Edit/View/Save ControlCAL Display Profiles Option.
+Load Display Profiles created by others.
+You can now toggle between ASCII and HEX Input Modes in the ControlCAL Terminal Window (Advance Mode).
+Internal Serial Command Format Support for many Manufacturers including BenQ, Epson, JVC, Panasonic, Pioneer, Mitsubishi, Sony (including Sony Checksum), Sharp and more....
+Internal Support for Mitsubishi HC Series Projectors - Profile can be used as a starting point for Creating a Profile for your Display.
+Many Internal Code Changes...
+More info Coming Soon......
*v1.4 RC1 is a Time Limited Version and will expire on May 31, 2008.
post #45 of 80
can you elaborate a little more on your initial goal of finding undocumented commands ??? I'm sure the HC1000/1500u has some
post #46 of 80
Has anyone tried to use girder to control the HC4900? I need a little help trying to get it to work
post #47 of 80
Just looking for info on rs232 on/off control for Optoma EP771. I'm using a laptop that has no serial port. Is there an adaptor to connect USB to serial? If so, will that work? Thanks, Greg Spokane, Wa
post #48 of 80
This is the usb adapter I use:
post #49 of 80
Do you think it would be possible to control the iris with this program?
For instance, instead of having the iris open all the way maybe way could we have it move to a position like 3/4 open 1/2 open or 1/4 open or what not. This would act like the HDholic's mod on the HC4900 I would think!! Just a thought
post #50 of 80
It has to be in the RS232 command list--you can change iris *modes* I believe but you can't control the iris position via RS232.
post #51 of 80
This can be done now with one of the Slider Controls (depending on Command Format) but the next version will have 6 Buttons that you can assign codes to (i.e. one Button for Power On, one for Power Off).
The next version will also have 6 additional Slider Controls (#13-#18) which are complete now, a Pioneer ISFccc Mode (with a Locked Display Profile Version released) which is almost complete now, the Buttons, complete and I may have the dedicated (and universal) Gamma Controls Complete....
Laserfan is correct, the 4900's known Serial Commands only support the same 4 IRIS Modes that you can set with the Remote (Open, Auto IRIS1-3)....If there was a command available, ControlCAL could support it..
-Shawn
post #52 of 80
Here is a pic of ControlCAL (next version) loaded with the new Pioneer 8G ISFccc Display Profile I am currently working on.
What you don't see is another small undocked window with the Gamma Controls and up to 4 additional buttons (3 used for the ISFccc Display Profile, ISF DAY MODE, ISF NIGHT MODE and SAVE SETTINGS. I may release this version and the Display Profile before the Gamma Controls are ready. There are other issues (and feature availability) I have yet to decide.
post #53 of 80
Nice app. But I can't get the terminal window to appear. I'm in "Advance" mode, hit everything from F5 to F12, and can't get anything to bring it up.
post #54 of 80
When you start ControlCAL, the Terminal Window (what I call Advanced Mode) is visible, or should be.
What is your screen resolution? Try moving ControlCAL's Main Window, the Terminal Window may be behind that.
There is no Function Key that shows/hides the Terminal Window, you must use the Menu.....
-Shawn
post #55 of 80
Nevermind. Once I restarted the app it came up.
Fun using the Terminal window with the RS232 manual.
Great work.
post #56 of 80
Hi there turbe!
Would like to comment the Kuro ISF interface.
First of all, one thing I'm curious about: does the TV self-enumerates it's capabilities in a "telnet server" fashion, or did you get somewhere the Kuro RS232 reference?
About improving: it looks like you left out the 9 point gamma tracking...among many other menu settings.(color space, all the filters, etc)
If you can, you should place all the available options into your app! You could use tabs, to avoid too complicated windows.
For example,
- in the main tab I would place the basic settings, contrast, color, tint, sharpness, color space, gamma
- in a secondary tab all the filters and enhanchements
- in a third tab Colour temp & manual RGB highs/lows
- in a fourth tab Colour management (RGBYCM)
- in the last tab the 9 point gamma settings
-...... are there other undocumented programmable options???
post #57 of 80
Originally Posted by blutarsky View Post
Hi there turbe!
For example,
You must have missed "What you don't see is another small undocked window with the Gamma Controls" above.. I have dedicated Gamma Controls but I am still working on them. Getting them working with Pioneer is not a problem, but I need my Gamma Controls compatible with several Manufacturers..
Here are the other options available in ISF Mode for Pioneer 8G:
Y-Delay (0-7)
Pure Cinema (Off, Standard, Advance, Smooth)
CTI (Off, On)
Color Space (-, 1, 2)
Block NR (Off, On)
Black Level (Off, On)
ACL (Off, On)
3DYC (Off, Low, Mid, High)
I-P Mode (-, 1, 2, 3)
Text Optimisation (Off, On)
Intelligent mode (Off, On)
DRE Picture (Off, Low, Mid, High)
Enhancermode (1, 2, 3)
3DNR (Off, Low, Mid, High)
Field NR (Off, Low, Mid, High)
MosquitoNR (Off/On)
As far as the Serial Codes, I have the Official Documentation and I have agreed not to publish this information.
I put the Gamma Controls in a separate small Window - this window can be disabled within the Display Profile. My goal with ControlCAL is to have the the Controls on one screen and I am targeting Users with Widescreen displays on their computer running ControlCAL.
Shawn
post #58 of 80
Here is a pic of the undocked Extras Window (ControlCAL has the Pioneer ISFccc Display Profile loaded) which has Buttons and Dedicated Gamma Controls.
Each Button can be configured independently, Enabled or Disabled and this Window is only Visible/Active if one of the Buttons or the Gamma Controls are Enabled. The Buttons with the Label "TEST" are not used (and not visible) in the ISFccc Display Profile.
Ignore the Gamma Color Combobox in the pic, I had this Control Enabled before I took the screencap (Pioneer does not require this option but it is used for other Manufacturer's Displays).
The Gamma Controls are 'Work in Progress' so the layout and options may change (though I have what I need for the 8G Pioneers).
post #59 of 80
I'll have a go with your tool! Yep you should stuff all the settings somwehere. When calibrating you may adjust all the filters...
BTW: what are those small input fields and the send buttons?
post #60 of 80
You can directly enter values in the 'Input Fields'.
ControlCAL does not automatically send the value of the Slider when you move it, you must use the SEND Button to send the value (either from the Slider or from the Input Field). This was a design decision of mine.
-Shawn
