AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Nevo Q50 Owners Thread
Nevo Q50 Owners Thread - Page 2
post #31 of 803
Sorry for my english
By soft buttons, I mean the 4 hard buttons that you can configure as you like with the LCD.
See the link and the explanations of remoteshoppe :
http://www.remoteshoppe.com/images/r...q50-layout.gif
In fact, i would like to use these 4 hard buttons and "edit" them with colors in order to create "color hard buttons"
For example, in this case :
http://remotequest.com/large%20Q50%20icon%20page.jpg
I would like to replace "PVR menu", "Services", "List" and "Aspect" by the color buttons that are juste above.
I hope that it's clearer than before
Thanks in advance
post #32 of 803
ah, those are alas just text labels, captions for whatever you set when programming the four top buttons (let's forget the hard/soft divide for a sec - I blame Remoteshoppe! ). I've not double checked, but I couldn't even see a nice way of setting font or colour for those. I'll dig into the software, and if you can change background/text style for those captions than you'd be fine, but I'm not hopeful.
You can of course set those to the =function= that you wish, but you might not be able to colour them.
post #33 of 803
Thanks sharkshark
I hope that the backgrounds of the 4 TOP buttons can be changed, one by one, but It would be a miracle.
Otherwise, maybe a future upgrade of the software is likely to make it possible ?
It would definitly be a great feature, IMHO
post #34 of 803
Hi Flyingboy,
While I don't think you can change the background color of the soft button labels, you can pick the font colors and size of the text on top of it. So, you could probably create a rectangle (maybe just use a large bold hyphen or dash) in the color you choose, on top of the grey background. Should look about the same as those color buttons you have on your second screen shot. Make sure you have the "use default font" setting set to off, or you won't be able to change the font size and color.
post #35 of 803
yeah, you can use one of these ("—") if you want as well... As per NYC's (always) correct suggestion, you can set font and colour, but not bg colour....
post #36 of 803
It's a first step
If you can already change the color of the font, It means that with a ("-") in bold, it could be ok
Thanks a lot for you two
post #37 of 803
enjoy, note mine's an ascii emdash, not just a dash. It's longer!
Plus, bold usually doesn't affect characters like dashes at small size. Remember you can also use a custom font, so find a nice box font and go crazy!
post #38 of 803
If anyone is still looking for the Q50- feel free to give me a call-
Matt
We are an authorized dealer. Offer support and next day shipping. We do not sell online so you must phone me if interested. Internet sales are prohibited by Nevo.
The SL was discontinued.
I am expecting to get several S70's in the next few weeks.
EDIT** The S70 just went into production and is expected withing the next 90 days. Retail for the unit will be $1199 and dealer cost is still tba.
feel free to call me @ 913.208.0733
post #39 of 803
...I use mine for lighting control, but good, ol' fashioned Lutron IR in my HT room (hardly the "home automation of the future" promised in the, well, past, but certainly enough to wow friends that don't spend time in the switch dept. of home depot.
As I think I said above (tooo...tired...to...scroll...) the UI codes were particularly bad for the Lutron stuff, so I was forced to use learning mode like a sucker.
The Z-wave stuff certainly looks cool, but I honestly couldn't think of anything that wouldn't cost a fortune to control, and with line-of-sight to my equipment rack it was an expense I didn't feel like forking out for.
I'd be interested in hearing about how people use the RF component, it may sway me one day....
post #40 of 803
So the q50 can control z-wave devices? Im about ready to buy the q50 or s70. I had originally planned to use grafik eye but if i can just do zwave switches that would be much easier. From what i read the s70 will be able to access ips such as being able to bring up my cameras over the internet on my remote?
post #41 of 803
No, currently the Q50 only uses Zwave (RF) to talk to the NevoConnect and will not control other native Zwave devices. Although it may be enabled in the future via a software update.
Mark
post #42 of 803
I basically looking for the best way to control 6 zones of lighting without going with a graffik eye. I think the eye would be a waste because the remotes control system could handle the scene settings.
post #43 of 803
You would still need some sort of light controller regardless of the remote you use.
Joe
post #44 of 803
Originally Posted by sharkshark View Post
...I grant you that the up/down keys are wasted on the other devices - I've set them to control my lutron, up for "dim up", down for power off. A quick, easy way to get some illumination.
I'm just now finishing my HT and have the Lutron spacer system and am looking at what remote to get. When you do macros with the Q50 can you easily set the remote to lets say have the lights do a task when you hit the play button to watch a movie or have certain lights go back up when you hit the pause button? Just curious on how well it works with the lutron IR and macros
thanks
post #45 of 803
thanks
I am doing that exact thing with my MX-3000. I would guess it would be as easy with the Q50.
Joe
post #46 of 803
Hi everybody !
I've got mine since this morning.
I am testing Nevostudiopro : it's awesome !!
The remote is in charge since 5 hours but the indicator at the top right of the screen is still moving. Is it normal ? It seems that only 4 hours are necessary to an entire charge ?
Thanks for your help
post #47 of 803
Joe
Thanks Joe. I was hoping that this would be pretty easy to do with newer remotes.
Originally Posted by Flyingboy View Post
Hi everybody !
Give us a report when you get time
post #48 of 803
Can you control Sonos with the Q50?
post #49 of 803
Edit: Nevermind...been reading more and more about this remote and understand the software can most likely only be used/tried after buying the unit.
So, let me ask this...
I have used Pronto and Logitech software previously...and I very much knew what I was doing with the Pronto software (I even used to submit my CCF files over on Remote Central back in the day and created many different setups)...will I have any issue setting up a Nevo Q50?
post #50 of 803
You shouldn't have any problems with the software. I have found it to be quite intuitive. Also, the pre-recorded training sessions on mynevo.com should answer any questions you have.
post #51 of 803
Thanks DCulver
Trying to decide between the Q50, the SL, or waiting for the S70.
hmmmmmm....
Coming from the Harmony 1000...so whatever I get will be an improvement
post #52 of 803
Mike,
I have the SL and the Q50. The drawbacks of the SL for me have been somewhat cumbersome Wi-Fi, and no hard transport buttons. The Q50 has solved both these issues. I just wish the screen had the same resolution of the SL.
Frankly, I'm surprised there's not a lot more "buzz" about this remote.
post #53 of 803
Dennis
Thanks for your feedback. Since the rest of my setup probably won't be ready for a few months, I'm most likely going to hold out and see what the S70 release brings...maybe it will top and better both the SL and the Q50...I just hope the price is similair
Thansk again, I think I have definitely decided upon Nevo...and I'm suprised about the lack of "buzz" as well...seems like some great products!
post #54 of 803
I think the reason there isn't a lot of the buzz is due to nevo only has 2 remotes, but yet they want to cater to the installer. I myself want a bit more of a selection for my client not just 2 remotes. Companies like RTI have a wider range of models. Not everyone likes the same style remote or price. The s70 and q50 are almost same styling.
post #55 of 803
I'm trying to incorporate favorite channel buttons into my Q50 scheme. I've found a site, guifx.com, which has handy button/logo software.
I've managed to load Q50 button images into the software and then apply network logos to it-- they look great, but these buttons are static-- they don't change appearance when pressed. And I can see that the Q50 gallery does have .png files for both PRESSED and UNPRESSED states, but I don't know how to go about incorporating both images into one button.
So my question is: how do I go about creating custom buttons which have both UNPRESSED and PRESSED states into my scheme?
Thanks in advance for any guidance!
post #56 of 803
If you don't want the image to change when pressed, simply copy the button file in the same folder it's in and rename the files with the addition of "_0" (unpressed), and "_1" (pressed). Make sense?
post #57 of 803
Anyone been able to connect a Q50 from a Mac running a Win XP SP2 Virtual Machine using VMware Fusion? Active Sync will not recognize the controller in the Virtual Machine. I have been working with VMware for a week trying resolve the problem but no luck yet.
I also have a PC so I am able to connect the device that way to program in Studio Pro, but would really like to use the Mac instead.
post #58 of 803
One tip for the Q50 :
when you configure the same running time for the screen AND the unit ( for example 30s.) then both hard buttons (every ones) and the screen can wake up the remote
And the hard buttons will light on with a great blue.
post #59 of 803
Great tip! I'll give this a go tonight.
Mark
post #60 of 803
No, but I was able to get it working with Boot Camp.
  Back to Forum: Remote Control Area
