So according to the manual of the simplicity full motion wall mount I just bought from costco..I need to install it on vertical studs (at least in the picture). Only problem is the only studs I could find in the wall where my TV would be are all horizontal. That and the spacing between the two horizontal studs I believe are larger than the mount, meaning only the top or bottom half of the mount could go into the studs.
My TV is roughly 75 lbs (42" LCD Vizio TV). Would it be safe to just mount the bottom or top half to a stud, and the other half use dry mount anchors? or am I asking for a tv ripping from my wall to come crashing into my ent. center? Anyway just trying to avoid having to cut into my wall to place vertical studs. If placing vertical studs in the wall is my only option for using this mount...does anyone know a good website I can use with good DIY instructions on how to do that? I'll fully admit i'm new to the whole DIY thing when it comes to walls/dry wall, but willing to learn whatever I can.
~G
~G
