seams barco is first out with the new jcv 4k pr.
form the pictures you can see its the jvc pr. but it has some
diferences like the light out.
jvc still say 3500 lumen barco say "till" 4500 lumen?
NO HDCP
for more infos see this link or down.
http://www.barco.com/Presentation/en...p?element=4068
LX-5 technical specification
Light output
4,500 lumens
Contrast ratio
> 10,000:1 contrast ratio
Resolution
4,096 x 2,400 pixels (10Mp)
Display technology
LCoS
Lamps
Lamp
800W Xenon
Lamp lifetime (typical)
Warranted 750 hrs - max 1,500 hrs
Dimensions
Weight
Body only: 50kg / 110 lbs
Height - width - length
390 x 660 x 830 mm
15.35 x 25.99 x 32.67
Lenses
Available zoom lenses
TLB HB (1.5 - 1.9:1) included
Available fixed focal lenses
TLB HB (1:1)
Features
Special features
Up to 4 picture-and-picture data and images
Adjustable color temperature
High dynamic range compatible
Inputs and outputs
Inputs
4x dual DVI-D (up to 12 bit)
Communication ports
RS232 in/out on D9
RJ45 (10/100 Base-T Ethernet)
USB port
Compatibility
Data
Computer graphics formats VGA, SVGA, XGA, SXGA, UXGA,
1080p HD, 2K up to 4K and 10MP
Safety
Safety regulations
UL 60950
CE compliant
RoHS and WEEE compliant
Power
AC power
100 - 240 VAC/50-60 Hz
Max. power consumption
1500 Watt
Order info
Order info
LX-5 R9011220
NO HDCP
Light output
4,500 lumens
Contrast ratio
Resolution
Display technology
LCoS
Lamps
Lamp
800W Xenon
Dimensions
Weight
390 x 660 x 830 mm
Lenses
TLB HB (1:1)
Features
Special features
Inputs and outputs
Inputs
Communication ports
RS232 in/out on D9
USB port
Compatibility
Data
Safety
Safety regulations
UL 60950
CE compliant
Power
AC power
1500 Watt
Order info
Order info
LX-5 R9011220
Years ago there's Graphic4000 which is OEMed from panasonic and after that Barco built their own two lamp projector's design. I believe the next LCOS series projector will be based from the SIM7 series
