Originally Posted by
rwestley
...I think that some may be having handshake issues caused by other equipment they own.
Yes, possibly.
rwestley
...It may not be possible to use any switch in some cases.
True, but many (not all) have changed their switch and the problems disappeared.
rwestley
...When SA came out with there first cable box I could not get the HDCP handshake. They have resolved the issue with firmware updates.
This is my problem - the switch works fine with my Toshiba player, but not with my Moto DCT3416I STB. Some on that box's thread hint that a firmware fix could be the solution. Too bad Comcast won't release the newest firmware in my area.
rwestley
...They can not be responible for HDMI/HDCP issues caused by other links.
I think it is a lot more complex than that.
What we are talking about here is more of a quality control issue. Sure there are a lot of people who use this switch without any issues. But, when the manufacturer responds to a request for an RMA with instructions to try each HDMI input on the device to see if using a different input solves your handshake problem, that indicates to me that the device they shipped is not 100% compatible on all ports. All the inputs should work the same, right? But I've seen some people report that indeed, changing the input port solved their problem.
While my problem is definitely the Moto STB, I think it is possible that the problems others are experiencing are more likely due to the switch as opposed to their other equipment.
And lastly, yes - damn HDCP!
