AVS › AVS Forum › Video Components › Home Theater Computers › .mkv in Vista Media Center?
post #1 of 6
Is the only way to get .mkv files to show up in VMC by putting them in the "videos" folder? I tried adding my movies folder from another hard drive to the watch list but they don't show up in VMC.
post #2 of 6
show up just fine for me, do you have haali mkv splitter installed? Also check out this addon that allows you to control MKV features in VMC
http://damienbt.free.fr/index.php
post #3 of 6
yep, i installed coreavc w/haali, i'll check out the link.
post #4 of 6
Mine show up in media center using the mymovies plugin. I can also browse them over on my server just fine.
They don't show up in the list of DVD's in media center though.
post #5 of 6
Well, I tried installing my movies, but i keep getting some error during install and ffdshow does't work well on my computer for some reason, so media control is out of the question too. i guess i just have to rely on renaming the files to .avi
post #6 of 6
Did you do the necessary registry entry? I remember doing that when I was setting mine up, but it was so long ago.
