AVS › AVS Forum › Display Devices › CRT Projectors › Can someone post MTF pattern tiles? The archives is down!
post #1 of 9
post #2 of 9
Funny you just asked i am making a 1920x1080 test disc right now on iDVD waitng for it to burn. I used some test patterns i down loaded form a nec test pattern site cant remeber. I'll up load them to my Marquee down load site.
Maybe if i have the room I'll add the test disc i made up too.
Link to test patterns
http://homepage.mac.com/nashou.66/FileSharing9.html
Athanasios
post #3 of 9
Send the link to the hdnet pattern i'll add it to my set up disc
once i find a 720p patterns I'll make that too.
edited link to my above post.
Athanasios
post #4 of 9
post #5 of 9
post #6 of 9
Athanasios
Is there a reason the intensity of the focus dot pattern varies through the pattern? Seems like that wouldn't be a good idea.
post #7 of 9
I havn't really looked at those yet on my theater screen just tested it on my comp. I found them some where from a link on one of the AVS forums but never booked maked it.
Athanasios
PS. if some one has a 720p test pattern like the avec one for 1080i it be great also looking for a 1920x800/817p pattern for 2.35/40 aspect ratio for those who want to do Active area scanning to run higher refresh rates with out loosing bandwith.
post #8 of 9
1031, JPG is not a good format for images like this. It tends to "blur" the patterns, which is exactly what you don't want. GIF or PNG is much better for sharp-edged computer-generated images.
post #9 of 9
Thanks, thats good to know.
  Back to Forum: CRT Projectors
