Here's some replies.
Originally Posted by
RoubaixPro
1. Can the SSP-800 be stacked directly on top of the CA-5300 amplifier?
Yes.
Will there be any heat issues by doing this? I have a Salamander cabinet with a closed front, sides and an open rear.
Maybe. Just putting the SSP in a cabinet with closed front/sides can be a heat issue depending on air flow. Add in an amp and it only gets worse, even if the amp is on top of the SSP.
2. Does the SSP-800 have a ICTTunnel cooling system to keep the component cool?
No. Just passive vents. The CT-SSP has fan cooling IIRC.
4. Is there a feature available in the Classe SSP-800 to switch to stereo direct mode bypasses and disables all digital processing for 2 channel analogue sources?
Yes.
5. Does the SSP-800 have a DAC built-in?
Yes. 10 channels of DAC.
If so, do I still need a separate DAC like the BADA Alpha DAC/Alpha USB?
No need, but that never stopped anyone.
6. Can the SSP-800 be controlled by a universal remote like the Harmony One?
Yes.
