Originally Posted by Sharp1080
I was running prior to upgrading to a new projector a week ago a 25 ft length HDMI 1.3 spec from my SSP-800 to my old Infocus 7205 and never had a problem. I have upgraded to a new projector JVC RS55 and replaced the HDMI cable with a 1.4 spec cable without a problem. Maybe try a different HDMI cable? You know that the signal is being transmitted from your Oppo. Not that it is the same issue but don't you have to routinely clear out the "cache" or "que" in the Oppo? Not sure if that's the right word for the function on the Oppo?
Thanks guys. My Oppo plugged directly to the HDMI cable works fine, but when it is plugged into the SSP it works for a few seconds then snow. My AVM50 has no issues sending the signal over the same cable and if your experience has been that Your SSP works with long cables then i would conclude that it isn't the cable but the video board in the processor. I connected the Oppo to the SSP and the SSP to the Anthem and that setup works, but its not very practical. I'll be calleing Classe again.
Best,
Tim
