AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Official Classe SSP-800 thread.
Official Classe SSP-800 thread. - Page 164
post #4891 of 5459
Originally Posted by Roger Dressler View Post
And it's the only way to get the benefits of bass management and EQ.
Roger, can I still use the SSP-800's speaker/bass management with the 2 channel analog inputs as long as I don't enable Bypass Direct?
post #4892 of 5459
^^ Exactly. It's just like any other digital source at that point. If you want both options available easily, just build a second input using the same source, with the Bypass enabled.
post #4893 of 5459
Ok, firmware update is done and thanks, Roger, for the tips on the config. I have one more question concerning Dolby Volume. I see how to configure it in the menu for Low or High and to enable the modeler. But I don't see how to assign it to only specific inputs. I only want to use it on DirecTV and not on other sources. How do I accomplish that?
TIA,
Karl
post #4894 of 5459
It's on the Favorite Processing menu.
>Menu
>System Setup
>Input
>Audio
>Fav.Processing
post #4895 of 5459
Is it true that the little screens that are predominantly blue switch to red when there's some sort of problem?
Would it be at all possible to reverse taht, so they're red most of the time and they swsitch to blue when there's a problem. Blue clashes with the WAF's planned colour scheme.
I know it's an extremely long shot, but I am always so very optimistic. It seems like it could just be some sort of mobo dipswitch. Or maybe even a patch that could be written to the firmware... or something.
post #4896 of 5459
>Menu
>System Setup
>Input
>Audio
>Fav.Processing
Ok, thanks Roger. So I enable Dolby Volume in System Setup - Dolby menu and then select what input to apply it so under the Input setup, right?
Karl
post #4897 of 5459
Ok, thanks Roger. So I enable Dolby Volume in System Setup - Dolby menu and then select what input to apply it to under the Input setup, right?
Yes, the Dolby menu is a handy global control, easier to reach than the deeper audio menu setting.
post #4898 of 5459
Would it be at all possible to reverse that, so they're red most of the time and they swsitch to blue when there's a problem.
I have mine set to red all the time, as that works better with the red walls.
>Menu
>Display
>Colors
post #4899 of 5459
Ok, got the Dolby Volume working and now for my next question. Under what Modes does the SSP output an audio signal on the SUB output? I know the sub is connected because I can generate a test tone to it when doing the speaker balancing. However, neither SAT TV or SACD inputs seem to be using the sub. The SACD is connected via analog XLR #1 and the SAT TV uses a HDMI connector. I have the audio on the SACD input set to Stereo 2channel and the SAT TV input is on Dolby Movie + Dolby Volume is enabled. It could be the source material because I haven't had time to test all the sources with different material but are there only certain processing modes where the SSP will output to the SUB?
Karl
post #4900 of 5459
There are only two ways to get a signal out the sub output.
a) 5.1 source (or 7.1), which uses the LFE channel.
b) Bass redirected from main channels. This requires setting some speakers = small.
It does not matter what surround or DD Vol modes are used.
post #4901 of 5459
Thanks, Roger. Another problem solved, I have my L & R Revel Gems set as large or full range. I'll reset them to small and that should do it for the 2 channel sources.
Karl
post #4902 of 5459
Hello Roger
Are you going to CEDIA this year smile.gif I wish I could but I dpon't have time, plus Indianapolis of all places wish they aletrnated the location and had it on the west coast! SF or SD
post #4903 of 5459
Originally Posted by wse View Post
Hello Roger
post #4904 of 5459
While installing the upgrade I did something wrong. The standby blue light keeps flashing and I cannot stop it from flashing. After many minutes I powered off and on the SSP but it still is flashing. Any suggestions?
post #4905 of 5459
^^ First confirm you are using the correct series of firmware for your hardware. 2.0.6 for the original HDMI 1.3 (dual DSP); or 3.0.2 for the newer HDMI 1.4 unit.
The just start the process all over again from step 1. You are not the first one who has had to repeat the process to make it stick.
post #4906 of 5459
Thanks Roger
On the Operation page "update firmware" is checked. On the next pare Backup " initializing" appears but the message quickly changes to "Transfer Error"
Any suggestions?
post #4907 of 5459
^^ Any chance your PC has not had the "Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)" installed?
If that's all good, then you might need to try rolling back to the 3.0.1 code, and after that is successful, go for 3.0.2 again. BTW, I'm assuming you have the HDMI 1.4 hardware. Yes?
See the saga starting here and ending at post 1941.
Edited by Roger Dressler - 9/3/12 at 5:01pm
post #4908 of 5459
Looking to add a turntable with a MC cartridge as a source for my SSP. Looking for recommendations on phono preamps that pair well with the SSP.
TIA
post #4909 of 5459
Roger Thanks. My problem was my old PC. I use a Mac but keep the PC for downloads etc.
Carl Bastien of Classe tech support suggested I use Downloader 1.2 instead of 1.3 and it worked perfectly. Thanks again
post #4910 of 5459
Hi guys,
I'm just slowly building my system and unfortunately I went the wrong route on some of the products I purchased hence why I'm here with my question. I'm tossed between the Bryston SP3 vs the Classe SSP 800.
Any info would be great
I'm running all logans speakers and Lexicon power am with an Onkyo receiver which is what I'm replacing.
post #4911 of 5459
Glad you got it sorted. Even though I used downloader 1.3 as required for the transition to HDMI 1.4, I have always used 1.2 since, and now I know why!
post #4912 of 5459
>Menu
>Display
>Colors
That is *exactly* what I wanted to hear about it. I have the same sort of thing going on, so red is strongly wanted to match the rest of the red.
It's really hard to find units with red lights instead of blue!
My next question is about whether the CT-SSP is truly exactly the same as the SSP-800, and whether it will have the same support lifecycle.
Has anyone done a/b testing with each unit?
The insides are arranged kinda differently, and on some boards this can affect things.
Also, (And I guess this is for Roger, cause it seems like he's the Classe ambassador to this place) can you tell me what the sales ratio is between CT-SSP & SSP-800?
thanks!
post #4913 of 5459
Could somebody please tell me why I can't view either the stereo analogue bypass or the 7.1 analogue bypass. I cannot find them anywhere. I'd like to be able to listen to CDs in analogue.
Thank you.
Rick
post #4914 of 5459
Originally Posted by ichy View Post
Hi guys,
I found this thread. http://www.avsforum.com/t/1423873/bryston-sp3-vs-classe-sp800-vs-audiolab-8200ap
I don't think any of the classe fans have voiced themselves in it yet, so it's all about the bryston.
OF course, there's strongly voice advice about auditioning units there, too.
Edited by nemir - 9/6/12 at 4:07pm
post #4915 of 5459
Thank you.
Rick
For Bypass Direct for 2-channel you go to System Setup and than to input hit next input until you get to the 2-channel analog inputs and than go to audio that is where you will see the Direct Bypass and where you would select it. As for the 7.1 Analog connectors if you are using them for the audio then 7.1 Bypass is automatic and unelectable. I have actually gone into the menu to try to turn it off but could not and that is because I am connected also to the 7.1 analog inputs. Perhaps Roger could confirm this as he certainly knows the SSP-800 and helped me out a few times.
post #4916 of 5459
Here is what Dave Nauber said on the matter.
There is a minor difference in the code package due to how the LED operates. Other than that the firmware is identical and always the same updates are provided to both versions.
I have no idea about sales, sorry.
post #4917 of 5459
mt14942,
Thank you very much for the reply. I sure hope this works for me.
Rick
post #4918 of 5459
Too bad we can't get this in the SSP-800
Harman Announces JBL Synthesis ARCOS Room Correction Updates
September 7, 2012
At CEDIA 2012, HARMAN’s JBL Synthesis is announcing it has updated its ARCOS Adaptive Room Correction and Optimization System to Version 2.6 for WindowsXP, which incorporates a number of performance and user interface upgrades for faster operation and improved system calibration. ARCOS is an integrated software and hardware package that provides precise accuracy in setting up and calibrating a JBL Synthesis multichannel audio system.
In related news, HARMAN Research Acoustician, Todd Welti, will be presenting a paper at the 133rd AES Convention detailing new research into the behavior of multiple subwoofers in listening rooms. Thanks to new modeling software that Welti has developed, a larger variety of subwoofer configurations and placements can be modeled more accurately.
In all rooms, there are resonances or room modes that emphasize some frequencies and attenuate others, detracting from in-room frequency response accuracy. ARCOS v2.6 compensates for these irregularities more precisely than ever before and provides time delay correction and other benefits, to achieve flatter frequency response and extraordinary sonic realism.
ARCOS v2.6 offers 10 times faster AutoEQ calculation than previously. The time it takes to calculate a speaker channel’s required EQ compensation with up to 20 bands of parametric EQ is now reduced from over a minute to about six seconds. In addition, the AutoEQ feature now provides an Iterations function that enables the AutoEQ to calculate the multiple interactions involved in the process and get a more accurate room correction answer including how the various EQ bands interact with one another. In addition, the upgrade offers improved AutoEQ settings for better timbre-matching of the left, center and right speakers in a multichannel audio system, for more accurate subwoofer low-pass calibration and more accurate location and correction of room modes via “ringing” out the room.
In a major functionality enhancement, ARCOS now provides native support for more Harman HiQnet-capable devices in addition to the SDEC models already supported. HiQnet is a communications protocol that enables compatible devices to communicate with one another and act in synergy to deliver enhanced performance capabilities. The expansion of HiQnet in ARCOS will enable future expansion into more products and facilitate end-to-end connectivity using a unified system language.
The ARCOS user interface has also been improved. The displays now run up to four times faster, giving graphing updates and user input better smoothness and feel. All graphs can now be zoomed and panned, allowing the user to see much more detail when zeroing in on a “problem” frequency. The legends on the graphs are more legible.
The ability to compare the individual speakers in a system by overlaying their frequency response graphs is greatly improved, as it is now possible to add and remove multiple overlaid channels at once in real time. Additional interface improvements include an improved microphone calibration page, better Help menus for the final listening and source setup steps, better display of speaker crossover functions and JBL Synthesis SDEC4500 and SDEC3000 equalizer/crossover bass management functionality, and many additional enhancements.
The JBL Synthesis ARCOS Adaptive Room Correction and Optimization System is supplied with all the hardware, measurement microphones, software and accessories needed to calibrate a JBL Synthesis multichannel audio system. ARCOS is currently available to all authorized JBL Synthesis dealers and system integrators
post #4919 of 5459
And just how much is the current Synthesis setup going for? It's around $178,267.50! wink.gif
post #4920 of 5459
Thank you.
Rick
By the way I neglected to say that you can listen to 2-channel music without Bypass Direct selected, This gives you the option of using the SSP-800's speaker, bass management and EQ. I am planning on experimenting with this. I know of at least one person who goes that route for stereo music, I am curious if that's how most SSP-800 owners do that? I myself don't have the expertise yet to mess with the EQ but I can adjust the speaker levels, delays and bass management like I have done when I listen to 5.1 music or watching a bluray so I won't have to move my listening chair so I am right in the middle.
