The unit comes with a special hexagon shaped screw driver that is used to remove the 3 screws on the bottom plate of the remote. I have had my SSP-800 for I think a couple of years now and have never had to replace the batteries.
Official Classe SSP-800 thread. - Page 177
AVS Top Picks
- Roger Dressler
- Trader Feedback: 0
- offline
- 7,458 Posts. Joined 7/2000
- Thumbs Up: 35
- Select All Posts By This User
The same tool accesses the innards of the SSP through the top plate, not that there's any user serviceable parts inside.
- wse
- Trader Feedback: +1
- offline
- 3,030 Posts. Joined 3/2008
- Thumbs Up: 49
- adidino
- Cinephiliac
- offline
- 3,832 Posts. Joined 12/2003
- Thumbs Up: 19
I think resale value will hurt a little. When I had my amps listed, I was asked by a few interested buyers if they were China or Canada made. Although I think the quality shouldn't be impacted as Classe claims they oversee operations in China, some are still concerned about it.
- wse
- offline
- Thumbs Up: 49
Yes that is what I am afraid of, well as long as they perform well for the next ten years then I will be fine.
Has any one tried the Ayre VX-R it is a beauty!!
- G-Rex
- offline
- 693 Posts. Joined 10/2002
- Thumbs Up: 13
- ClasseAddict
- offline
- 6 Posts. Joined 8/2012
- Thumbs Up: 10
See Ya,
Steve
- wse
- offline
- Thumbs Up: 49
I own Classe product made in Canada and China. When the announcement that Classe being made in China originally held merit and cause for concern was legit. however my made in China CP-800 and SSP-800 both work flawlessly and have met my expectations. The resale value may dip a little for made in China product, but only time will tell if that trend holds up. In my opinion...what will drive resale value of Classe products will be how they compete against products of similar price point and feature sets. So far Classe has done well in that regard. Specially the CP-800 recently has excellent reviews and has been a segment leader. The SSP-800 has aged well, yet still competes with the newest SSP's. If Classe launches hardware upgrades the SSP-800 will continue to be product worth consideration in the high end SSP arena. The newer Classe amps still go head to head with other amps in comparable watts and specs. I have not seen any Classe products selling for cheap prices due to being made in China, but very little of it has been on the market long enough to be "for sale" on the used market. Classe product made in Canada still sells for fair Blue Book prices. See Ya, Steve
So what is the Blue Book Value for the SSP-800? My SSP-800 was made in Canada and my VP-800 made in China.
As far as I can tell same quality, both work fine so far. When do you think will Classé upgrade the SSP-800?
- Bigmoviefan
- online
- 488 Posts. Joined 4/2007
- Thumbs Up: 14
See Ya,
Steve
Really high.
- wse
- offline
- Thumbs Up: 49
I agree I can't tell the difference so far let's hope that it remains true as time goes by!
- Alsof1
- Alan Sofer
- offline
- 21 Posts. Joined 2/2013
- Thumbs Up: 10
I have just taken delivery of a SSP800............It certainly does not look ,feel ,act - or sound as if it was assembled in
China .
I should imagine that Classe as a company have ensured that the move to assemble ( not produce ) in China is as good if not better than where they previously produced their products .
I also have 2 B&W DB1 subwoofers, I think produced in the same facility- fit and finish is top class .
These products are assembled in a purpose built factory and not alongside toasters and kettles........so yes , guess I am not too upset about it !
By the way , how do you change volume setting from relative to absolute and vice versa ?? Mentioned in n the manual , but for my life cannot find it !!
- buttecreeker
- offline
- 173 Posts. Joined 11/2007
- Thumbs Up: 10
Press the "Menu" button. Located the "Display Setup" page. Then pick "Volume". It is at page 51 of the owners manual (version2.2) that is.
Dave
Edited by buttecreeker - 2/27/13 at 12:58pm
- wse
- offline
- Thumbs Up: 49
I have just taken delivery of a SSP800............It certainly does not look ,feel, act - or sound as if it was assembled in China .I should imagine that Classe as a company have ensured that the move to assemble ( not produce ) in China is as good if not better than where they previously produced their products .
So you kow that Classé has their own manufacturing in China, that's what I though as well.
- Alsof1
- Alan Sofer
- offline
- Thumbs Up: 10
Thanks Dave........was looking for this in Menu/System Set up/Volume rather then in Display - Got it , thanks .!
By the way on the low volume Bass issue using Aux 2 input and two subs .The Classe does not double up on volume when using two subs as other processors tend to do ,but evens the volume /signal
out .
Have set up my Revel Studios and Voice as Full range , 80 Hz Xover and Subwoofer +Ebass.........My two DB1 subs are best they ever been -linear , smooth response due to all speakers at Full range and sounds great l!!!
Just got to learn how to torture the SSP800 and the system to get the best it can give ..get there and you are made !
- wse
- offline
- Thumbs Up: 49
Thanks Dave........was looking for this in Menu/System Set up/Volume rather then in Display - Got it , thanks .!By the way on the low volume Bass issue using Aux 2 input and two subs .The Classe does not double up on volume when using two subs as other processors tend to do ,but evens the volume /signal out .
2 B&W DB1 subwoofers" Cool I wonder how they compare to the JLAudio in terms of musicality and slam?
How can you have speakers set to full and 80Hz crossover it is either cross over or full range!
- Alsof1
- Alan Sofer
- offline
- Thumbs Up: 10
Simple ......... You set up your L/R/C speakers to FULL in the speaker set up menu of the Config you are using .
You must still tell the subs where to Xover from and what range to receive - in my case 80HZ and below is what I want the subs to receive - you do this by going to the Xover menu in the speaker set up menu and set to your required Xover ........your speakers set will then run full range and bass will be duplicated in all speakers Plus the sub , but in my case 80HZ and below is what subs will be receiving according to the xover I set .If yo do not do this the subs will be receiving a full range signal which of course is not wanted . Trust this clear ????
Someone correct e if I am wrong , but this only way to do it .
Also read up on This in Frequently asked Questions -Classe ............http://www.bwgroupsupport.com/faqs/classe
- Koresh38
- offline
- 4 Posts. Joined 11/2012
- Thumbs Up: 10
- buttecreeker
- offline
- Thumbs Up: 10
My understanding is that "e-bass" must be enabled, in order for the bass to be steered to the sub (below the crossover Hz), in addition to the bass being sent to the mains.
I noticed that Alsof1 had said he was enabling "e-bass", in the previous post.
Dave
- Roger Dressler
- offline
- Thumbs Up: 35
Edited by Roger Dressler - 3/1/13 at 12:16am
- wse
- offline
- Thumbs Up: 49
Just curious. If the Studios are good down to 30 Hz, why duplicate the bass from 30-80 Hz in the sub eith e-bass? Doesn't that make it difficult to balance the bass <30 Hz with the rest? Or are you doing that with PEQ in the sub? If so, then that messes up the LFE response.
Interesting indeed!
- Alsof1
- Alan Sofer
- offline
- Thumbs Up: 10
By duplicating the bass in the the 80 to 30 HZ range in both my subs and the Studios ,I have managed to smooth the response audibly in my otherwise challenged square room .
I believe this is also one of the( apart from other ) reasons the ability to use Full + Sub + Ebass exists as quoted by Classe in their FAQ session I posted the link on .
Apart from a +7 db notch at 38zHZ ,I also have a bass suck out of up to -13 DB between 52 and 68HZ ........by duplicating the bass , at present after many hours of alternatives, it is best it has ever has been in the room and displays great sensitivity , musicality and slam - factors which are difficult to obtain and hard to come by as we all know !!.
I have run the Auto EQ on the DB1's , however I am not a fan of Auto EQing and the fact that B&W have not designed their EQ software for two subs I have been told, so better left alone .
I might add that one sub is difficult enough to set up properly - two subs are a nightmare !!!
My dealer will measure my room and EQ the SSP800 manually in the near future and I can then revisit - at present though, all sounding great which is the object of the game ,notwithstanding how you get there .
- Roger Dressler
- offline
- Thumbs Up: 35
- ollegg
- offline
- 19 Posts. Joined 3/2013
- Thumbs Up: 10
Now, this occurred quite late in the day, after a whole Saturday spent plumbling the SSP in and experimenting with my Oppo 105, so this maybe the unit overheating, as it's running a little hot at 55°C, this being my temporary set up.
Any advice would be greatly appreciated.
- ollegg
- offline
- Thumbs Up: 10
- Roger Dressler
- offline
- Thumbs Up: 35
Greetings, it's good to be here, glad i found this forum. This is my first post, and a question. I noticed, quite weirdly, that the stereo feed from my Mac Mini goes into the Surround speakers, not in the fronts. The only way to make it play via FR/FL is to switch into Music plus/party Mode. I'm running 5.1 config. In a stereo mode the sound disappears completely.
If consistent, sounds like a simple plumbing problem. Please describe the signal connections from the Mac to the SSP.
Also, make sure that when you run the internal test noise signal, the sound is heard from the speaker being displayed.
If is happened out of the blue, see if it persists after a cool down, if temperature is a concern.
- Roger Dressler
- offline
- Thumbs Up: 35
Another question. Oppo, for their 105, recommend dual HDMI output with HDMI 2 carrying audio only, but i could not configure the SSP's Input's audio connector to be another HDMI while taking video feed from HDMI 1. I know i could run just HDMI 2 into the SSP-800 only, but i wanted to run the video through the SSP to switch between projector and plasma. Thank you.
The SSP has 2 outputs, so you can feed the 2 displays that way.
- wse
- offline
- Thumbs Up: 49
You mean it was working fine, then did an about face?? Or is it consistent since you completed the wiring? If consistent, sounds like a simple plumbing problem. Please describe the signal connections from the Mac to the SSP. Also, make sure that when you run the internal test noise signal, the sound is heard from the speaker being displayed. If is happened out of the blue, see if it persists after a cool down, if temperature is a concern.I had a similar problem last night while switching mode temperature was 42C so not a heat problem. I got a blue screen saying "Please Wait" waited for 10 minutes and had to hard reboot the SSP-800 !
- ollegg
- offline
- Thumbs Up: 10
Roger, many thanks. It's the former, though it was my first day with the unit, and i tried a few permutations of connection, so it's difficult to compare apples to apples. The stereo signal from Mac Mini (iTunes and flash video like BBC iPlayer site), which played fine on internal buzzer when unplugged), fed in through Opt1, and HDMI, same result. Strangely, the DD feed from iTunes video worked fine at the same time. The SACD from Oppo 105 was fine in 5.1, but a CD did not play through LF/RF.
- Roger Dressler
- offline
- Thumbs Up: 35
- ollegg
- offline
- Thumbs Up: 10
there's one more issue that's been bugging me. When switching between two inputs which have same Video connector but different Audio one, I lose video, and get "the green screeen on death". Eg. I set up two inputs for Oppo 105, one with HDMI audio and another with XLR -- to compare the DACs on 105 and 800. When I switch between these two modes, I get the green screen. Any idea why and is it curable?
- Official Classe SSP-800 thread.
AVS Top Picks
Recent Discussions
- › calibrate 2 minutes ago
- › Would a projector work for me 2 minutes ago
- › Confused about speakers and TV. 3 minutes ago
- › Purchase for parents? No internet but want XBMC type experience... 6 minutes ago
- › Portable Bluetooth Speaker - which one? 6 minutes ago
- › whats the best sub for the money max $500 8 minutes ago
- › Paradigm studio 60 and cc590 compared to McIntosh xr50 and lcr80 9 minutes ago
- › Official AVS National HD Channel Lineups - Cable/DBS/Fiber/IPTV -... 11 minutes ago
- › 2013 4K Harman Kardon AVR 2700 & 3700 receivers 12 minutes ago
- › Louisville, KY - HDTV 12 minutes ago
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
