Jvc Rs2.....
post #1 of 66
i just set up one of these yesterday and it's a bigger upgrade from the RS1 that i'd though based on the mediocre CEDIA demo. The colors seem a little more accurate, the settings are close to dead on, the focus is better (made easier with the remote focus/zoom which is superb!). Blacks are about as black as one can hope. I still notice a bit of grain that could just be source and maybe some motion issues that i don't notice on DLPs, but still, quite an upgrade from the RS1 with precious few flaws. i'd be surprised if anything below $20k or $30k has much to offer that it doesn't do.
post #2 of 66
Great to hear I've not seen it yet. What kind of clibbrated lumens are you getting ?
Art
post #3 of 66
I'd be surprised if anything below $20k or $30k has much to offer that it doesn't do.
Is that a question?
post #4 of 66
Art
Hi Art, not sure about that one. I don't have a sensor for that. My guy is all by eyes (which is easier these days that it was).
post #5 of 66
I am getting about 371 lumens at D65 on the RS2 (after calibration...it wasn't all that close out of the box).
post #6 of 66
My RS1/HD-1 has only less one hundred on the bulb.......maybe I should go after RS5
post #7 of 66
Sub 400 here too (396).
post #8 of 66
Jason and CM, are those numbers short or long throw? High or low bulb setting?
Just curious.
Best Regards,
Doug
post #9 of 66
Crap that is low. I need to measure mine. I will have pre-calibration measurment now and I will do a post after I get my Radiance back from the shop.
What did you measure from the RS1 calibrated?
post #10 of 66
Jason. I assume you are doing a review. Should come out almost simultaneously with Greg R's in WSR (on line). Would you be so kind to post a screen shot of the lens resolution pattern from DVE projected through this projector? Thanks
post #11 of 66
Just curious.
Best Regards,
Doug
It is low, but there are worse lumen performers out there costing more. 8ft wide screen @ 1.3 gain was giving 13fl and will fade to under 10. Small screens only unless you can tolerate a high gain screen.
post #12 of 66
Jason. when you measured the RS2 at what zoom position were you. I have read reviews which for D65 go anywhere from 350-550.
post #13 of 66
Testing the zoom full range gave 334-421.
Hope that helps
post #14 of 66
Originally Posted by mark haflich View Post
Jason.i assume you are doing a review. Should come out almost simultaneously with Greg R's in WSR (on line). Would you be so kind to post a screen shot of the lens resolution pattern from DVE projected through this projector? Thanks
I looked at the RS2 last week and it looked fairly sharp , not great but good. There is a review of an RS2 which shows a shot under "RS2 sharpness" and there are two pictures one of a numerical display which demonstrates mild softness and one of a dinner table which demonstrate some of the haze I would call it blooming or crosstalk. other than that the color looks fine to me. So its a mixed bag but still a very good value.
http://www.projectorreviews.com/jvc/...agequality.php
to answer a previous question I do not know what glass they are using in the very complex 16 element lens they use in the RS2 but as we say in the optics industry it has a lot of glass which means it should have enough glass to produce a beautiful image. That does not mean it does produce a sharp image but it should.
The quality variation is so large that you are essentially rolling the dice when you buy a single chip and especially 3 chip projector from anyone. If the panel alignment doesn't get you the lateral color aberration will, which is why I think the zonal convergence adjustment on the Sony VW-200 is an overlooked big deal. Its the only way to correct for both panel misalignment and lateral color.
post #15 of 66
Jason, what were the methods you used for calibration? Are you talking DVE, etc., or a full on calibration like Wm and others do?
Chris
post #16 of 66
Also was this normal or high lamp mode?
post #17 of 66
I do a full calibration on the unit before measuring. I ranged from the lower 300's to upper 300's...similar to coldmachine (but there are some hours on this one as well). I no longer do measurements in my reviews so when it comes up please don't expect them. This was merely FYI.
The RS1 ranged but I found it to be more like 450-600 depending on the unit.
post #18 of 66
If not posting numbers on your reviews, why give them out at all?
Just curious as it doesn't seem to make sense.
I for one, as many others, would love for you to put them back in your reviews. It seems much to easier to compare reviews from the same reviewer.
post #19 of 66
The problem is one reviewer say Jason measures something and another reviewer say Greg measures something else. Why are they different? Because? Throw, measuring equipment, bulb age, yada yada. I do think that numbers between reviewers don't mean much but numbers do have some relevance between machines from the same reviewer.
post #20 of 66
Yeah but he just said from the same reviewer.
post #21 of 66
Validation me boy. I was validating what he said. You know the +1 follow on post. You can't reach 7000 plus posts without a few +1s.
post #22 of 66
+1 on that ^
post #23 of 66
Jason, can you give us some more info on how you like the RS-2? How much of an upgrade does it seem like over the RS-1?
post #24 of 66
I agree with that, and I would add calibration limits and measuring technique to your list Mark.
post #25 of 66
That's, of course, included in the yada yada.
post #26 of 66
Agreed completely.
post #27 of 66
How would I test to find out my lumens??
post #28 of 66
Accurately might be hard...but first you'd need all the proper gear (test pattern generator, light meter, etc...). Not something most end users bother with.
post #29 of 66
Validation me boy. I was validating what he said. You know the +1 follow on post. You can reach 7000 plus posts without a few +1s.
Ahhhhhhh. I see the light dude. For some reason I thought you were poorly arguing with him.
post #30 of 66
Yeah only deranged losers bother with that stuff.
Ummmm wait nevermind. (Hides his ca813)
