i am a bit confused.
i read numerous adds for the A550 Samsung and the european version, the A557, and sometimes they state that you can add the 3D glasses and sometimes they do not.
on the european models I only saw the 3D glasses feature mentioned with the smaller A457 models.
anybody know more about this?
and i also read that the usb input will only display still images and play MP3s. is there a way around this?
i mean, who listens to MP3s on his plasma? why not add DivX support or something like that? or will it be possible to tweak the firmware to support this?
the european models are said to be 1080/24p. so i would be surprised if the us model was not as you usually get added features. and aren't all 1080p plasmas capable of 24p by now?
Whats the deal with 1080p/24fps, yes or no?? I'm guessing no if it is not anywhere on there spec sheets
