Originally Posted by
imws
I just looked at the specs for the 42" model and it clearly states "Perfect Pixel HD". In fact I couldn't find any mention of Pixel Plus 3 HD. Anyway I hope it's the newer chip.
If you look under the techincal specifications its the very first thing mentioned under picture enhancement. I emailed philips I will let you know what I hear. Below are the specs I am talking about.
Perfect Pixel HD Engine offers the unique combination of ultimate sharpness, natural detail, vivid colors and smooth natural motion on all qualities of HD, standard TV signals and multimedia content, for high definition displays. Each pixel of the incoming picture is enhanced to better match the surrounding pixels, resulting in a more natural picture. Artifacts and noise in all sources from multimedia to standard TV and also in highly compressed HD content are detected and reduced ensuring that the picture is clean and razor sharp.
Full HD LCD display, with a 1920x1080p resolution
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
View more features
View less features
HD Natural Motion for ultra smooth motion in Full HD movies
Philips invented HD Natural Motion to eliminate juddering effects that are visible with movie based picture content. HD Natural Motion estimates motion in the picture and corrects juddering movements in both broadcast and recorded movie material (such as DVD and Blu-ray Disc). The resulting smooth motion reproduction and excellent sharpness take the viewing experience to a higher level. HD Natural Motion removes judder from SD and HD pictures, including 1080p, for a motion performance that surpasses the cinema!
120Hz Clear LCD, 2ms performance for superb motion sharpness
120Hz Clear LCD creates extreme motion sharpness for clear and vibrant images even with fast on-screen motion. The Double Frame Rate Insertion works with a high 120Hz refresh rate. It increases the sharpness of motion reproduction to more than twice that of conventional LCD, resulting in a response time of 2 milliseconds (measured in Perceived Blur-Edge-Width; BEW). This unique Philips technology brings motion sharpness of LCD displays to an unprecedented level.
ATSC & QAM tuner receives over the air and unscrambled cable
Built-in ATSC & QAM tuner for reception of over-the-air and unscrambled HD cable programs
Invisible speakers with incredible surround
An invisible sound system that blends perfectly with the design of the cabinet. The Incredible Surround allows you to experience total surround with greater depth and width of sound. It gives a clear and spacious sound stage complementary to the rich viewing experience.
30 watt with BBE for powerful sound and great voice clarity
BBE high definition sound is the core sound enhancement technology (licensed by BBE Sound) that will enable you to experience real natural music, speech intelligibility with rich and clear audible vocals.
4 HDMI inputs for full digital HD connection in one cable
HDMI makes an uncompressed digital RGB connection from the source to the screen for the ultimate picture quality. HDMI intelligently communicates the highest output resolution with the source device. The HDMI input is fully backward compatible with DVI sources and includes digital audio. HDMI uses HDCP copy protection. With 3 HDMI inputs on the back and 1 HDMI on the side of the TV you can connect multiple HD sources, for instance an HD settop box, a Blu-ray player, and game console or digital Camcorder. Your TV is fully prepared for the HD future.
EasyLink: easy control of TV & connected device via HDMI CEC
EasyLink uses the HDMI CEC industry standard protocol to share functionality between connected devices and the TV. With Easylink only one remote control is needed to operate main functionalities on your TV and connected devices. EasyLink uses the standard HDMI cable to transfer system commands. It works between all electronic devices equipped with HDMI CEC.
Settings assistant for effortless personalized TV settings
Settings assistant for effortless personalized TV settings. The new settings assistant personalisation wizard guides you to personalised settings with unparalleled ease. It includes not only picture, but the complete viewing experience, including sound and Ambilight settings. The wizard shows a few screens with easy to choose options to select the essential settings. The TV performance is set to the your personal preference without difficult terms or settings, and this very quickly.
Dolby Digital output for connection to a home theatre system
Technical specifications
Picture/Display
Aspect ratio Widescreen
Brightness 500 cd/m²
Dynamic screen contrast 29000:1
Response time (typical) 2 ms
Diagonal screen size (inch) 42 inch
Diagonal screen size (metric) 107 cm
Panel resolution 1920x1080p
Picture enhancement Pixel Plus 3 HD , 3/2 - 2/2 motion pull down , 3D Combfilter , Active Control + Light sensor , Dynamic contrast enhancement , Progressive Scan , 120Hz LCD , HD Natural Motion
Viewing angle (horizontal) 176 degree
Viewing angle (vertical) 176 degree
