Originally Posted by politby
That easy, eh? Will test this tonight when I get home from work.
I have TMT set to autoplay BD/HD DVD and VMC to autoplay DVDs and that all works fine when I insert a disc, but I'd really like to have both tiles so that I can start play of either format when a disk is already inserted, by just using the mouse. Any way I can get the "Play DVD" tile back and still have the TMT tile?
/politby
/politby
My Play DVD button did not go away.
But you can try going into the settings portion of VMC and find the applications portion. In there you will find the installed apps and startup apps. You can uncheck items to make them go away. TMT will have about 6 or 7 entries I think. Uncheck them all and add them back one at a time until you have only the ones you want. I removed all but the one which says ArcSoft HD-DVD and BR (I think it says that).
