Originally Posted by
DJWikiera
What is your System, OS specs. I read you had driver issue's with your HD4650 card, that could be the problem.
bdhdcheck says all ok but software
his 4650 with latest drivers
opteron 2.2 ghz, 2 gb ram windows mce 2005
install is virgin from reformat( i use acronis )
powdvd works fine on seperat virgin install
no other codecs installed and hardly any other software
arcsoft update complete to version 2.6.something
mpg's ok. avi's ok
using mce and tv wont work (stuttering vid, no sound) just installed total media demo(got confused thought it was a newer version of tmt) and tv works fine with this
weird
