AVS › AVS Forum › Video Components › Home Theater Computers › Arcsoft TotalMedia Theatre
Arcsoft TotalMedia Theatre - Page 146
post #4351 of 4419
Originally Posted by slydog75 View Post
Is anyone having issues playing Back to the Future 25th Anniversary with TMT2? The menu loads up but then when I go to play the main feature the screen just goes blank.
OK, I used AnyDVD to disable BDLive and it works now.
post #4352 of 4419
Originally Posted by myoda View Post
What is the make and model of your receiver? How are you getting audio to your receiver? Usually, if you pass PCM to your receiver, the receiver will indicate that it is getting a PCM stream, and indicate on the front panel PCM or Multichannel.
Dave Matthews & Tim Reynolds: Live at Radio City Music Hall, as an example, has multiple soundtracks:
PCM Stereo Sound (48kHz/24bit)
Dolby TrueHD 5.1 Surround Sound (96kHz/24bit)
Dolby Digital 5.1 Surround Sound (640 kbps)
Are you selecting the correct track?
The Hangover Blu-Ray disc was not encoded in DTS-HD MA - as far as I can tell these are the tracks available:
English: Dolby TrueHD 5.1
English: Dolby Digital 5.1
French: Dolby Digital 5.1
Spanish: Dolby Digital 5.1
Portuguese: Dolby Digital 5.1
If you can provide more info on your setup, a solution could be forthcoming. Thanks.
I have a Yamaha V663, and I run a HDMI cable from the computer to the receiver then to the TV. The receiver will show PCM when I select mix to PCM but I have no idea if the correct track is being sent.
I guess I was reading the display wrong on my receiver. Both movies are TrueHD. So TrueHD shows up for Hangover but not Dave Matthews. I selected each of the three audio tracks and PCM showed up correctly as PCM output, Dolby showed up as Dolby output, but TrueHD only showed as Dolby (640 kps). Hangover showed TrueHD on TMT3.
post #4353 of 4419
I can't figure out how to do slow motion with this software. Please don't tell me this is not an option. Arcsoft is closed on Saturdays, which seems silly for $10 a call.
post #4354 of 4419
As a note, TMT5 allows you to select this in the program. Enough people bitched about the studios messing up BDLive that Arcsoft now allows us to disable it.
post #4355 of 4419
I get stable playback when launching TMT3 from desktop and playing from ripped folders. However, I am having a problem when launching tmt3 from media center. The video will freeze, audio when still go on, until everything freezes. It will recover again, but will remain choppy.
I have 4gb of ram, a core i3 h55 system, so hardware is not the issue. Besides, like I said, playback is perfect from desktop!
Any ideas??!!
post #4356 of 4419
Playing from disc, ISO, or folder...and where is the non-disc located if you are using it?
I found I have to occasionally power cycle my switch and reboot my storage server to clear up studdering issues.
post #4357 of 4419
Playing from folder rip on local computer and stored on DIY windows home server. I have experimented some more, and I think it was random that it was an issue from within media center. Seems like certain discs have persistent issues, like it is a movie studio issue. Sex and city 2 and Jonah hex bad, predators and robin hood flawless.
post #4358 of 4419
I usually run into issues with the LionsGate films. That clockwork at the start seems to kill things.
post #4359 of 4419
Any ideas??!!
What type of video card are you using. I run ati 5670 and I find as of right now catalyst 10.9 to be the most stable and has the fastest vidoe playback speed. When I upgraded to 10.10 or 10.11 the video became choppy with audio pauses and dropouts.
post #4360 of 4419
I'm currently running Totalmedia Theatre 3 Platinum with the 3D patch. I tried playing back MvA and Bolt in 3D and was getting seperation of the picture. Basically I would see double images as the video was playing. Basically it was like everything was out of focus. I tried updating the Catalyst software to 10.10 and 10.11 but that made the video playback chopping and did not fix the image issue.
I have the overscan set to 0% and I tried turning the GPU scaling on and off but that had no effect on the problem. Has anyone else have any ideas what I can do to get this working?
post #4361 of 4419
Can anyone confirm they're able to play this disc with any version of Arcsoft TotalMedia Theatre?
I'm running v3.0.1.185 and both players (uDTStart.exe,uMCEDVDPlayer.exe) hang after selecting the 5.1 track
I'm on win7 64, ati 5850, catalyst v10.9
I have TotalMedia Theatre v5 but haven't installed it yet.
I'm really only looking for confirmation this title *can* play with *any* version of TotalMedia Theatre at this point.
I'm well aware of the myriad updates and hotfixes for both the latest v3 and v5 versions of TotalMedia Theatre as well as the ATI Catalyst drivers so no need to suggest I investigate those from folks who haven't actually tried this specific title etc.
thanks!
post #4362 of 4419
Just picked up TMT3 and seems to play HDDVDs that I have fine. I am using the XBOX's HDDVD player on my laptop and it also runs it when using Windows Media Center to play back HDDVDs. It does what I need it to do if I wanna take HDDVDs on the go. I have a standalone BD player and so I only use this for HDDVDs when not hooked up to the xbox.
post #4363 of 4419
There is only one functionality I miss badly in TMT now, which exists in the alternatives. I really would like a keyboard shortcut to skip a specified number of seconds forwards or backwards (useful if you miss something and would like to re-watch).
Can something like this be achieved by any other means?
post #4364 of 4419
Quick call for help here, folks!
Installed the GTS 450 in my HTPC today and installed latest drivers including 3D Vision. Updated TMT to latest version also.
Playing back 3D for the first time from my HTPC through the Denon 4311.
I'm seeing the Denon as the display in my windows setup, not the RS40.
And the 3D Avatar disc gives me an error in TMT saying that it doesn't detect a 3D display device.
Any thoughts?? Sorry if this is a dumb question. Help!
post #4365 of 4419
If you had an ATI, I would be inclined to think it was an EDID issue which has been known to happen with Denons. I didn't say anything in your other thread though since you have the 450 and I wasn't sure if they have the issue. Tulli may know if that is the case though.
As a sanity check though, do you have the Denon set to do upconversion or straight video passthrough?
Edit: See rica's answer in the HTPC 3D thread.
post #4366 of 4419
I was messing with my audio receiver yesterday and when I launched "kick-Ass" iso from my desktop I couldn't get HD audio. If I switched to PCM in TMT3 my receiver would show PCM and all 7 channels receiving signal. When I switch to back to same as source it would say DTS and 5 channels receiving audio.
Now if I launch the movie from inside WMC7, my reciever would display DTS HD when playing the movie, but it would only show 5 channels receiving signal not 7. Kick-Ass is a DTS-HD 7.1 audio mix right? What's going on? My receiver is a Yamaha V633.
post #4367 of 4419
post #4368 of 4419
Just installed TMT 3 on my new build. I am using ATI 5750.
May I know how do I set TMT3 to bitstream audio?
post #4369 of 4419
I'm having problems playing Blu-rays from folders using TMT3 (v185). I don't seem to have any problems playing from disc.
I have an ATI Radeon HD 5750 and am running Catalyst version 10.12. My system has an Intel Core i3 540 and 4 GB RAM and I'm running Windows 7 Ultimate 64-bit.
When I try to play from folder, it changes the color scheme to basic and seems to start. After the first screen, the TMT3 screen goes blank. At this point TMT3 becomes unresponsive. However, the audio keeps playing (probably the background sound for the menu). I have to use task manager to end the process. When I try a second time, I get the bluescreen of death reboot.
post #4370 of 4419
Did you apply the Audio Hotfix 01 for TMT 3.0.1.185 necessary to support the Catalyst 10.12 drivers?
post #4371 of 4419
Yes, previously, I did install that audio hotfix and it doesn't make any difference. I still cannot player Blu-ray folders. I also noticed that 1 of those 3 files is actually older than the one included with the v185 update of TMT3. I tried it both ways.
I noticed that the TMT screen goes black just when it seems to get to the menu. And like I said, the music continues to play, but TMT doesn't respond to anything. I can only close it by going to task manager and ending the process. I also noticed a message on my taskbar, which was something like "Display Driver has stopped working and has recovered."
Thanks for your help.
post #4372 of 4419
Are you using the MC integrated TMT3 or the standalone application? I have not had any issues playing full folder rips of either blu-rays or DVD's since early on with TMT2. I have like 300 blu-ray folders and about 250 DVD's that I usually play from within MC using MyMovies3, but I do periodically use the standalone app when I am testing and I have no problems launching the movie from folders. I currently have both TMT3 & TMT5 installed on win7 x64 system using ATI 5570 video card and ccc 10.10e. Maybe tell us more details, standalone or MC interface, any library add-in, movie titles, what software you use to rip the folders (I use AnyDVD HD)...sorry if you have already provided this info.
post #4373 of 4419
Originally Posted by HTPCat View Post
Are you using the MC integrated TMT3 or the standalone application? I have not had any issues playing full folder rips of either blu-rays or DVD's since early on with TMT2. I have like 300 blu-ray folders and about 250 DVD's that I usually play from within MC using MyMovies3, but I do periodically use the standalone app when I am testing and I have no problems launching the movie from folders. I currently have both TMT3 & TMT5 installed on win7 x64 system using ATI 5570 video card and ccc 10.10e. Maybe tell us more details, what operating system, standalone or MC interface, any library add-in, movie titles, what software you use to rip the folders (I use AnyDVD HD)...sorry if you have already provided this info.
From my earlier post:
I'm having problems with the standalone interface. I haven't tried this with the Media Center interface and want to get it to work standalone first. I've tried this with several movies including, "One Flew Over the Cuckoo's Nest," and "The Social Network." I use AnyDVD HD to rip the folders.
post #4374 of 4419
Very Odd, OK when I navigate to the folder I click on the source icon, maybe it is a picture of a disc (I am away form home and am trying to recall from memory) and then point to the volume id main folder that AnyDVD has created and click OK which will launch the movie. Is this how you are launching the folder/movie?
post #4375 of 4419
The source icon is a folder. When I pick it, I then navigate to my Blu-ray rip folders. These were created using AnyDVD HD. I select the top folder, which has the title. In this case "One Flew Over the Cuckoo's Nest" (inside that folder are the BDMV and CERTIFICATE folders, etc.). TMT3 then starts displaying animated logos from the BD. At the taskbar, a message "color scheme has been changed to Windows 7 Basic" pops up. Then the main menu is suppose to appear on TMT's screen. The last time I tried, the menu actually did come up, but usually I get a black screen. Even if it does display the menu, I can't do anything because TMT becomes unresponsive.
I tried this with several other titles, and as it turns out, they work fine. I can only reproduce the problem with "One Flew Over the Cuckoo's Nest."
So there must be something unique with that BD.
post #4376 of 4419
BD folders was always hit or miss for me w/ TMT3 some worked some gave me a blank screen, I do everything from 7MC. I never had issues w/ ISOs so I just rip everything to ISO, but I'm curious to know why folders had issues. BTW I also use AnyDVD HD but not all folder rips were ripped using it's rip function.
post #4377 of 4419
Say that 3 times fast.
post #4378 of 4419
LOL I was thinking the same thing.
post #4379 of 4419
hi guys. sorry if this question already has been answered in this thread but can't fully go trough 146 pages, so will ask it here. just installed tmt5 and like it a lot, this is my first use of this soft, but having one big issue, cant choose from audio streams of mkv file, it only plays one that is set as a default, when with media player classic or gom i can do it in no time. can you please advise why choosing audio streams in mkv files is not functional? thanks in advance
post #4380 of 4419
Not to sound rude....but.....since when did a software maker had to consider every possible scenario as a "requirement"?? Who said TMT MUST MUST playback MKV or be able choose to audio tracks inside an MKV (or anything else related to MKV)??
I commend Jason for not blowing his top every time the word MKV pops up in relation to TMT....I probably don't have that kind of patience.
