Originally Posted by
vidabox
The version of the Arcsoft software that VidaBox will be selling is different from the retail version in the following ways:
- Our version is stripped down and will only have the player. No burning software, editing software, etc. This makes the software more stable as there are no extra (probably unwanted) features to compromise the system stability. We have been told that our version has a more stable core and our testing with regards to stability is very good.
I'm not so sure that it makes the software more "stable", because they are not extra or unwanted features. They are "additional" functionality. Even if you remove them, it should have little to no impact on stability the core of the software.
In addition, if that's the case, I certainly hope your versions costs much less than the retail version, if it doesn't have thos extra features.
vidabox
- There might be features implement in the VidaBox version that might not be available in the retail version. For example, in our version, the UAC pop-up that many of you see in the retail version is disabled. I don't think they plan on disabling this pop-up in the retail version.
I would not call that a feature, I'd call it a "configuration". I can almost promise you that, that type of functionality is controlled by a flag/registry setting and they are only turning it on and off. They will certainly not have a customized code base for partners. Can you imagine the coding horror they would be facing with code branching and merging, if they had to maintain different versions for different partners? (I'm assuming you are not the only partner, I'm sure Arcsoft is looking to have as many partners as possible).
vidabox
- The retail version will have a 2 to 3 week update schedule. The VidaBox version gets updates when VidaBox decides to make the updates available. We will make updated version available as bug fixes are implemented.
I'm sorry, I call BS on this. Vidabox certainly does not have access to the source code, so how will they make any updates THEMSELVES?? The updates will need to be made by Arcsoft, not Vidabox, and if they make the updates, I'm sure they will want to release them to everyone, not just their partner(s).
vidabox
- Our build is independent of the retail version so we are not tied to the retail version update schedule
Really? So, Arcsoft is actually dedicating resources, process support, code versioning and management, for a partner? That would be impressive if that is in fact the case.
vidabox
Arcsoft is not going to be holding back updates in their retail version simply so VidaBox can have a faster track for updates. That will not be the case. In some cases, it may be that updates may come at the same time for both versions.
That makes more sense.
vidabox
It is my belief that you will be purchasing a more stable product with minor extra features that make sense for HTPC use with the VidaBox version.
How so? And what are these "extra" features you talk of (besides disabling the UAC pop up)? In fact you just said that you won't have a lot of the authoring features of the retail version.
vidabox
Also, the more we sell of our version, the more weight we will carry with Arcsoft to have them fix bugs and implement new features. They are more likely to listen to one of our bug reports than an email from someone in this forum. We will do our best to report bugs that are brought to our attention to Arcsoft but we will only be doing that for users of our version of the software.
But, Vidabox is not in the business of selling software. It is in the business of selling Media Centers. I can promise you that Arcsoft will sell more retail copies than Vidabox because you guys will be bundling it with your Media Centers while anybody can go and buy the retail version, without buying any hardware. Media Centers are still a hobbyist market segment, and within that limited market you are competing against the DIY crowd as well. The DIY crowd will be buying whatever is the most "feature rich" version.
All that being said, I'm still very happy to see progress being made in bringing HD media into Media centers and I applaud your efforts.
