Hi Cantergirl, welcome to the forum! Do you know how many splitters there are in the cable system at your home? In my case, removing two splitters made a significant improvement on the SD digital channels. By adding a small distribution amplifier, I was able to add the two splitters back into distribution system without losing PQ.
SD digital picture quality is better coming from our dvr box than strictly coming from wall outlet. Not sure why though...
HTH (a little anyways!)
Rick
Rick
and it fell in such a way that partially distroyed the coupling where the coax cable (antenna) fits and it can't be serviced. Now since I don't want to throw the brand new tv at the garbage, I was wandering if there is a solution to this: to connect the antenna to a device that has a hdmi/video output (that can be connected to the tv). Any ideas?? Is there such a device or is there another solution to the problem?
(..I'll keep looking.
