Originally Posted by
TrainWrek
My just out of warranty set was diagnosed yesterday with a bad light engine. Is it cost effective to have replaced, or should I start looking for a new set. Any chance that Mitsubishi would do anything to help with the cost? From the reading I've been doing it seems that this seems to be a fairly common problem with their DLP's. Any help would be greatly appreciated.
I've heard stories of people have success with getting Mits to help with "just-out-of-warranty" situations. You may need to talk to a supervisor when you call their support.
A full-up light engine replacement is probably pretty expensive ($500+??). Can you describe the symptoms? Do you know how your tech concluded that it's the light engine that's faulty?
