AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › I need an honest non-technical answer to how much bigger a 52" APPEARS compared 42"
post #1 of 33
I'm wondering, I have a Westinghouse LVM-42w2 right now. I sit about 12' from the TV. It just looks tiny on the wall.
Will a 52" be sufficient? I stuck a tape measure on the wall yesterday and even went to BB to look at 52" but I'm having a hard time really understanding or visualizing the size difference.
I'm looking at the following:
* Toshiba REGZA 52HL167 ($1999 at Amazon, free ship)
* Samsung LNT5265F ($2199 at Amazon, free ship - also $2199 at BB but then there is tax )
* Sharp Acquos LC52D64U - $2349 Amazon shipped
* Sony Bravia KDL52W3000 - $2399 Amazon shipped
Here's the room:
post #2 of 33
An ideal size for 12 feet is 65", so no.
post #3 of 33
Well, there's no way I'm getting a TV that big unfortunately
What if I moved 2' closer to around 10'?
I modified my picture. Would a 52" look anything like those two lines I drew out?
post #4 of 33
52" is about All you could fit in that space .. so either of your selection would be nice. Oh, doesn't heat fm fireplace cause problem(s)?
the debate on distance vs. size is discussed here many times; I'm having same decision .. going w/ 52" LCD/only 1080i avail. (or) the Pio 5080 plasma/720p where distance vs. size vs. ascernible resolution is ideal.
edit: Sony 52W3000; poor off-angle (Tosh 52hl167), no bands (Sharp) no reflection (Samsung 5265).. etc.
post #5 of 33
52" @ 10 feet is still pretty far; you'd barely be able to resolve 720p let alone 1080p sources. For 52", I'd recommend a viewing distance of 8 feet. Moving your chair forward is a lot cheaper than buying a bigger set.
If you want to have an idea of how much bigger it is than your current set, just take a ruler along the diagonal and add 10". You'll see it's really not much and you really need 65"+ for 12 feet.
Resolution chart: http://s3.carltonbale.com/resolution_chart.html
post #6 of 33
Judging from the picture, he could fit a 77" wide set in between those windows. The Sharp 65" is only about 60" wide.
post #7 of 33
No way can I afford a 65" TV (what, like $5k? !)
I really can't push the couch too much closer either because it's over the TV and i'll be staring upwards haha
I just dont want tospend $2k on a TV to upgrade from 42" to 52" and then have it appear to be the same on the wall.
post #8 of 33
yes, that's true .. but wouldn't he 'not' want to 'overwhelm' that wall space/fireplace mantel area(?)
edit: cut-out template of rough guesstimate 52" x 34" and see how that appears fm sitting area(s).
post #9 of 33
Maybe consider a plasma? The 58" Panasonic TH-58PH10UKA is pretty nice and only $2,200. It has 1366x768 resolution, which is plenty for your viewing distance. And 58" is a very noticeable improvement over 42". Not to mention, your viewing angle is a bit steep, and a plasma doesn't have viewing angle issues.
post #10 of 33
I'm really hung up on the 1080p, perhaps because I watch blu-rays. Recently when playing video games to get the right "look" I've been in the habit of standing up in front of the TV so I can get closer. I really rarely play from the couch.
post #11 of 33
Check out the Viewing Distance Calculator for some guidelines.
Your screen is way too high ... at least drop it closer to the mantle.
You could do a 92" electric drop screen and ceiling mounted projector for under $1500.
post #12 of 33
Ugh. Now I'm thinking I'd rather not be in a situation where in a year I'm having remorse.
Maybe I should look at like a Samsung FTP5884 ($3200 shipped) which is 58".
post #13 of 33
I've never heard anyone say, "Oh I should have gotten the smaller one". I HAVE heard "We coulda/shoulda got the BIGGER one.
Scotty
post #14 of 33
58"
Why are you limiting yourself to such small a screen??
post #15 of 33
This is a tough one. I am more into LCD than Plasma because of my gaming habits and the fact that my viewing environment is full of ambient light during the day.
A 58" Plasma would be great there due to its viewing angle advantages. However if you have a lot of light during the day LCD would perform better (Plasma would give you better blacks in the evening though).
52" would be a nice upgrade and I think you would see the difference. A 57" LCD or 58" Plasma would really be noticable though.
post #16 of 33
Even with a budget I see 58" ones for $3300.
I can't possibly go over $4k in any circumstance. Ugh.
Well there are tax returns.
post #17 of 33
Well, that's why I suggested front projection. For $4k you could have a very nice 1080p 120" setup !!
post #18 of 33
Don't I have issues though with my room being bright? Plus I would need to get it installed which would be a bear probably. I do like projection
post #19 of 33
You can't resolve 1080p at the distances you're talking about; you need to stand 6-7 feet from a 52-58" screen to do so (check out the resolution chart I linked you, and follow the red line).
Plus, viewing angle is going to be a serious issue with the set up so high, and plasma will solve that problem.
post #20 of 33
Well I was just as Best BUy and checking out the TV's. They had one area on the wall wehere they had a 42", a 50", a 58" and a 63" all next to each other.
I'm really thinking I need to go minimum 58 at this point.
I like the projector idea but I do'nt have the motivation or energy really to install a screen drop in the ceiling, install the project mount on the ceiling, and then get all the wires (well actually it's just the one HDMI wire but still) up to it. Plus I don't have the darkest living room. The blinds are filtering and not blocking. The light isn't too bad - at night the sun sets through the windows that are to the left and right of the TV, so it really isn't that noticeable. THe only time watching TV kind of sucks is in the middle of the day.
It's funny I started today thinking , $2k or so. Now, I'm up to $3500
My wife is right though; we are'nt selling the house; we are going to be here for a while. We watch plenty of TV to warrant a better set. If I get one like this, I plan on keeping it there for at least 7-10 years this time. I'm thinking 58 might work. I have to go measure the window.
ALso, will the viewing angle be an issue? I have an angled wall mount now (which I need to replace) but if I just angle it down it should be fine, no? I cna't put the TV too low because of the jut from the fireplace mantle.
post #21 of 33
Actually I'm looking and in the 58+ range they are all Plasmas. I've never owned a plasma. What's the differences? are they OK for gaming? I've heard they have better black levels but how is PQ overall compared?
post #22 of 33
Fm what I've read here .. Plasma's have better viewing angles than LCDs; the angled mount should work. Newer plasma's have slight non-reflective coatings so glare shouldn't be a problem.
Minor break-in period (I've read) .. roughly 150 hours on medium (middle of road) settings ~50. IR (image retention) may be a problem; just don't keep static images on for too long(?)
Lastly, response times are a/r .01 I believe .. than LCDs.
post #23 of 33
Plasmas don't have viewing angle problems because the light comes from phosphors excited near the surface of the glass. Plasmas also have vibrant, natural colors, high contrast, and no response time issues as opposed to LCDs.
The downsides are image retention/burn-in if static areas are left up on the screen for a long time (the most serious issue IMO), high power consumption, increased weight (glass versus plastic), reflections off the glass, and low resolution on smaller sets.
Plasmas are NOT ideal for gaming or general computer use because of image retention issues.
Recent price drops have also made large plasmas very attractive; the 58" 1366x768 Panasonic is only $2,200.
Check out the Plasma forum.
post #24 of 33
get a 52" LCD, which is the upper limit of how much you are willing to spend, then adjust your couch accordingly.
post #25 of 33
The problem with moving the couch closer is that then I'd have to crane my neck. Looking up isn't bad when i'm 13' away but if I'm 8' away then it would be tough.
Are Plasma's really having a big burn-in problem? i've heard the newer ones today are pretty burn-in proof.
What's the reliability of a plasma vs. a LCD?
I think 58" is the size I need.
I also would really consider a projector; but I think the lighting in the room is just way to bright to make it work. I have an open floorplan and even if I blocked all the windows in the room I would still have all the ambient light coming through the kitchen.
post #26 of 33
I sit 11' to 12' away from my tv, and 52" is plenty big. I had a 46" before and felt it was too small. but I agree, take a tape measure and add 10" on the diagonal and that will give you an idea as to how much wider and higher it will be.
post #27 of 33
A 58" Plasma would do nicely in this application; especially considering the viewing angle. Gaming might be an issue though and Plasmas do take a fair bit of power. Some say it can run an extra $5-$10 per month to run a plasma.
So you are in a bit of a bind...
-Gaming and ambient light favour the LCD...
-Viewing angle and value per square inch favour the Plasma...
If you weren't a gamer I would vote plasma for you. They are supposed to be better than they used to for image retention etc. Hopefully someone can chime in who games on a plasma.
post #28 of 33
52 inches should be fine..............i have a 46 inch set at about 14-15 feet, its not that bad, 52 inches would be better though.
post #29 of 33
regarding plasma vs lcd...................its all about personal prefrence, personally i love the brighter picture of an lcd with lots of pop..... some people though like the darker, dimmer, more realistic look of plasma sets.......
and maybe, you could adjust the placement of your set, insted of mounting it on the wall you could put it on a stand at eye level, then you could move the couch closer.......
post #30 of 33
It's still an issue you have to watch out for.
You can't leave up static displays (e.g., Windows task bar) and if you watch a lot of the same non-native aspect ratio programming (e.g., a lot of 4:3 stuff with very little 16:9 stuff), you will want to use gray bars.
Suffice it to say a good one will last you a very long time. It should die of obsolescence first.
