Originally Posted by DonoMan
I have the same projector. It has GF9351 which is not bad. I wouldn't call it better than Realta - the question is how much better Realta is than it. My guess is that Realta is slightly better, particularly in the denoising department if that matters to you. The GF9450 which Lumagen uses is much better than the 935x and supposedly is pretty good at denoising.
No it will not be better than a good implementation of the Realta, but I knew what I was getting with the Marantz and the Gefen is still an unknown. It may be better (it should be) but it will not be much better. I really like the image from the 12S4.
Hope this unit is as good as it should be.
