Originally Posted by
laric
It was especially designed for low light measure and for sure it goes way beyond the above probes in that area... But, obviously, have it's own drawbacks, especially the need of calibration files (except if you allready have an i1 and so do your own files or probe trainning.)
--Patrice
Patrice,
Do you have any data from which you draw this conclusion? Not that I don't believe you, but the X-Rite i1Pro seems to be very highly regarded around here for a device under $1000 USD.
I see you have instructions for building your probe, but they are in French only. Any chance we'll get an English translation?
Also, is it possible to purchase your probe directly from you instead of having to build it oneself?
Does it already work with version 2.0.1 of the software or is it slated for support in a later version?
