AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › HDA30 can't get it to output DTS or DD
HDA30 can't get it to output DTS or DD - Page 2
post #31 of 33
There's no way you got DTS out of an HD DVD using optical over the A3. The A3 only puts out DD @ 640kbs over optical from HD DVD. Unless you were viewing (1) An SD DVD with a DTS soundtrack or (2) an HD DVD with a DTS-HD soundtrack (there's only one non-import - Pan's Labyrinth), then the output was most definitely DD.
post #32 of 33
Like it was said, the HD-A3 and A30 cannot output DD+, DolbyTrueHD or DTS HD and DTS MA. Those players don't support HDMI v. 1.3 and it is needed. I own a Duo HD Samsung BD-UP5000 an all HD DVD HD soundtrack are send to my receiver. The HD-A30 the output is only PCM but you don't loose from DD+ or DolbyTrue HD as the player can decode them and send them uncompressed through PCM 5.1.
post #33 of 33
You do realize this thread is almost 2 years old, right?
  Back to Forum: HD DVD Players
