AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Pioneer PDP 4280 qestion
post #1 of 9
Hey all
so I exchanged my PDP 4280 for another one because of the annoying buzzing coming from the back. My new one has a limted buzzing not as lound as my other one but the buzz is still there if you listen close. Its not as anooying but still it kinda bothers me because I dont feel right paying so much for a Tv that makes a buzz since im coming from a CRT that was dead silent. anyways i was wondering if anyone elses PDP 4280 makes a slight buzz from the back? I was also wondering what is the break in period and should i be doing it?
post #2 of 9
I went for the 5080 and there is no audible buzzing from the front, only a slight buzz from the back. If I had the buzz, I'd probably return it because, like you said, that much for a TV...
Breaking-in is kind of a "your choice" kind of thing - but if you're spending that much on a TV, why wouldn't you? My suggestion is to leave it muted on cartoon network, zoomed to full whenever you're not home/watching.
post #3 of 9
If you cant hear it from your viewing distance not sure how much better you can get.
post #4 of 9
Don't trade a display with an issue so minor because the odds are good you'll end up with something worse.
post #5 of 9
Is no one worried that the buzz would get worse? That'd be my fear...
post #6 of 9
I think there are very few that said that the buzz got worse. SMA can correct me if I am wrong and we can move this to the Buzz thread
http://www.avsforum.com/avs-vb/showthread.php?t=949003
post #7 of 9
If you're going to worry about that, why not worry that a set with no buzz will start to make one?
post #8 of 9
LMAO...pure classic!
Made my day...
post #9 of 9
OMG i connected my cable box to my pioneer and that buzzing came back... what a peice of crap. when is pioneer coming out with its 2008 42 inch? this **** is garbage i dont care how good the picture is it sounds like its gonna break down.
