Originally Posted by Kelvin1965S
Thanks for your comments and help. Now I've reconfigured my setup regarding 1080/24p I may as well stick to it and I only have a couple of 'video camera' shot BluRays so it is more accademic for me which is the best method regarding using 1080/60i or p into the JVC HD350, though if I come across the 'Benchmark' disc I may try it out purely on a technical level.
Now that's just rubbing it in....you have Radience units at work and at home.
I don't have many Blurays either. Just concerts which are shot in interlaced video and TV shows on SAT. For an RS1 the HDQ is great but for one of the newer projectors I would get a radiance I think.
If I had the money for a Radiance, I'd be considering buying a HD950 instead of my HD350...or at least an ex demo HD750. Then I'm not sure what extra benefit having a Radiance would be over the HDQ for watching mostly 1080/24p BluRays, with the CMS in the HD750/950 being better than what I have now in the HDQ.
) things that I should probably spend my money on.
