AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Digital Coaxial Switch?
post #1 of 4
Is there a such thing as a digital coaxial switch. I only have one coaxial in on my to be receiver and if I ever need another plug what would I use?
post #2 of 4
Some options:
http://www.gefen.com/kvm/product.jsp?prod_id=2616
http://www.inday.com/da4x/da4x.htm
http://www.smarthome.com/77705.html
You could also convert the coax to optical, if you have an optical input available:
post #3 of 4
WOW! Those are not cheap...ok thanks. I havent purchased my 5.1 audio yet but it only has one coaxial and 2 optical so I wanted to be sure they had these things.
post #4 of 4
4 x 1 HDMI Switch with Optical Toslink Routing -V1.3 Full 1080P with Deep Color Support
http://octavainc.com/HDMI%20switch%204port_toslink.htm
Scroll down for other options.
