Looking for a new subwoofer. I had a Velodyne HGS-12 that was fine for my taste but it just stopped working.
Budget: < $2000
Size: about 1 cubic foot or as small as possible
Room: 29'L x 25'W (725 sq ft) x 10'H = 7250 sq ft listening area but part of a "great room" that is double this size.
Use: HT and Music
Habits: Relatively low sound levels
Appearance: Patent leather/shiny piano black
Timeframe: Preferably before Christmas but no great rush
HT/Music System it will be a part of:
Receiver: Denon AVR-4308CI
TV: Pioneer Elite PRO-150FD
Speakers: Artison M-LCR, LRS-IW
DVD: Denon DVD-2910
DVR: DIRECTV Plus HD
Power Conditioner: RGPC 400 Pro
Budget: < $2000
Use: HT and Music
DVD: Denon DVD-2910
As I'm sure you can tell I am a newbie. I was referring to woofer size and not the overall dimension. Since my initial post I increased my budget up to $450. I've also been reading about the SV PB10-NSD and the HSU VTF-1. Thoughts?
) you can be sure that people will automatically recommend the biggest, baddest sub you can afford from an internet-only company you've never heard of. If you're determined to get a B&W subwoofer so it matches aesthetically with the rest of your setup, I'm just warning you that you might not be met with very much helpful advice
. That said, you don't need to get a B&W subwoofer just because you have B&W speakers - any quality subwoofer will sound great (it's not like matching speakers where it's important to have speakers that have similar sonic characteristics).
