AVS › AVS Forum › A/V Control & Automation › Home Automation › Lutron PC control interface
post #1 of 6
Does Lutron come with PC based control interface- Radio RA or grafik eye- or do you have to use 3 rd party software
thanks
mani
post #2 of 6
Both RadioRA and GrafikEye are PC compatible. I don't believe Lutron has their own control software, but you never know. MainLobby supports RadioRA and there is a 3rd party driver for the GrafikEye. One of our dealers wrote it.
post #3 of 6
CQC also has a driver for the rs232 interface.
post #4 of 6
The Lutron RadioRA Components page shows a Network Control Interface with the following to say:
The RadioRA Network Control Interface allows control of a RadioRA system through a web browser (Internet Explorer, Netscape Navigator, Microsoft Windows XP Media Center, etc...)
Can be used on any RadioRA job with a Chronos System Bridge or RS232 Interface and a home network
Control light through a number of popular devices devices (PC, PDA, tablet, touch-screen) or remotely
Allows control of up to 8 User pages and up to 15 scenes
Model Number: RA-NET-120
post #5 of 6
Does anyone have the software they can send me for the nci interface? It looks like I made the mistake of clicking auto upgrade in the advanced menu of the system. It wiped out the old file and tried to update it from a defunct in2nets web page. It looks like in2nets are out of business and as a result no file can be found. Pls help.
post #6 of 6
Looks like the NCI serves it's own configuration web page.
http://resi.lutron.com/LinkClick.asp...id=217&mid=679
  Back to Forum: Home Automation
