Originally Posted by
eightninesuited
Thanks a lot. Any ideas how much the Behr paint combo will cost me roughly?
Also, just to clarify, the projector will always be set to the theater mode which outputs about 371 lumens with some light during day time and completely light controlled at night.
A quart of the Behr Ultra 4850 is about $17 Cdn. A quart will do two coats on a 120" 16:9 screen if you bag the roller between coats. If you think there is a good chance you will need more then get a gallon. A gallon is four times the paint for twice the price.
You should plan on switching modes to suite the lighting conditions. You may want to go even lighter than what I first suggested.
~N9 DIY Tint {Light Gray}
Quart Custom Tint
Behr ULTRA UPW #4850
0 4 0 Lamp Black
0 0 1 Brown Oxide
0 0 1 Yellow Oxide
OR
Gallon Custom Tint
0 15 1 Lamp Black
0 03 1 Brown Oxide
0 01 1 Medium Yellow
This lighter gray will favor the complete darkness and the lower lumen output. When viewing with more ambient light you should switch to a brighter mode. In both cases you should do a brightness calibration using something like the THX Optimizer utility that can be found on the Cars, Nemo, and Terminator 2 DVDs.
