AVS › AVS Forum › Audio › Speakers › BIC Acoustech Owners Thread
BIC Acoustech Owners Thread - Page 137
post #4081 of 4576
If in-ceiling speakers are your only option then yes I believe you have chosen the speakers correctly.
Yes you should have a nice sounding and looking setup..... I plan on posting pics of my room this weekend.
post #4082 of 4576
Originally Posted by bgstewar View Post
How did you mount the PL-66s? They're such an odd shape, and I'm not sure how to mount them from my ceiling (beams exposed in a basement).
In case anyone wanted to know, I ended up buying some HDTV mounts based on another suggestion. I think they're gonna work perfectly!
And just placed my order for my PL200 sub. Can't wait...
post #4083 of 4576
I am currently running a PL-200 sub with my Elite SC-35 and I was thinking about ordering an Anti-mode 8033c for EQ on the sub. Has anyone used this EQ with their BIC sub? If so what were your thoughts?
post #4084 of 4576
Hi there im a canadian dude looking to build myself a good home theater
and so I was looking at this BIC Acoustech PL-89
http://www.ebay.com/itm/390412666522
But since its about 3-4 years old, do you guys suggest anything more recent ?
For both movies and games
post #4085 of 4576
Bic just released an updated Accoustech line. You can get it directly at http://www.acousticsounddesign.com/
They were offering a coupon... I think it was tv15. Enter that at checkout and you get 15% off.
post #4086 of 4576
Oh WOW thanks a lot for the info Tiberius (kirk) ! is there any difference between lets say
The PL-89II and the PL-89 ? im Looking on google and cant really find any answers yet
and on the Ebay link it kinda seams its the exact description... any ideas ?
Edited by Jackzor - 6/3/13 at 7:43pm
post #4087 of 4576
I don't think there's a huge difference. From what I've read BIC has changed the crossover which might improve some of the mid frequencies....but I don't know anyone that's actual auditioned them. On paper it appears that they might sound slightly better than the previous accoustech line.
post #4088 of 4576
cool would you go for the 1st or 2nd series if you were me ?
Just hoping it wont be a bad update eh :P
post #4089 of 4576
For me it would depend on the price. The pl89s are fine speakers and I get the impression they didnt improve them much. If I could save quite a bit with the 89 over the 89ii I would get the 89.
post #4090 of 4576
Boy that's a tough one.....I think I would get the 2nd series. The specs look good and Bic has a history of putting out good sounding speakers. It's hard to believe these would sound bad. I picked up a pl28 a couple of months ago. If I had known about the 2nd series coming out I would have waited.
post #4091 of 4576
How do you like your Pl89s?
post #4092 of 4576
I dont own them but Ive heard them. I like them fine but cant afford them.
post #4093 of 4576
You cant afford the pl-89s? Well then save your pennies, casue they sound great and you can get them for under 500 a pair. I got mine new for 450
post #4094 of 4576
Yes. So you've said several times. Its unlikely I will run into that kind of a deal.
post #4095 of 4576
I also got mine for $450/pair. That was the shipped price. I bought mine from acoustic sound design on 4/15/11. They are great to work with. Email them and ask for their best price and they will send it to you. I don't know if they can still sell these for $450, but it's worth a try.
post #4096 of 4576
Yeah I got my speakers in Feb of 2012. 2 - PL89, 1 - PL-28, and 4 - PL-66 for $989 shipped from acousticsounddesign.com. They are great guys to work with.
post #4097 of 4576
Thanks guys. I'll definitely keep that in mind when Im ready to upgrade.
post #4098 of 4576
Count me in as the same plus I got 2 PL-200 subs.
post #4099 of 4576
Any of you guys heard wheres a canadian can get that same kit without getting raped by transports fee ?
(newest models if possible)
post #4100 of 4576
http://www.amazon.com/gp/product/B00006JPDI/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
What do you guys think about these for front heights in a Klipsch system? How do you think they compare to the Acoustech PL66s? The tweeter in the DV62s concerns me. All my other tweeters are compression driven horns. But, again, we are only talking about front heights.
http://www.amazon.com/gp/product/B005YE7VM2/ref=ox_sc_sfl_title_3?ie=UTF8&psc=1&smid=A3MHJLSLQR2CVH
Edited by Bond 007 - 6/8/13 at 6:08am
post #4101 of 4576
Anybody know where I can find some HT64s?
post #4102 of 4576
Is the PL-76 setup overkill for a bedroom?
Should I just grab the towers + sub and skip the surrounds?
Edited by Pete the Greek - 6/8/13 at 10:14pm
post #4103 of 4576
You can never have to many speakers.
post #4104 of 4576
I am probably going to follow your suggestion of the pl66s for front heights. Thanks. smile.gif
post #4105 of 4576
You're welcome; & back @ ya, you showed me BIC speakers & that they are, in some cases, superior to the lower level Klipsch speakers!
Guy has a pair of RS-62II FS for $600, which is half price; wish I could swing 'em.
Let us know if they take an offer for the PL-66 pair, please!
post #4106 of 4576
acousticsounddesign said they would take a minimum of $199 for a pair of pl66s delivered.
Edited by Bond 007 - 6/9/13 at 4:49am
post #4107 of 4576
SWEET, so that makes them about the same price as those 89dB lack of efficiency Klipsch...
post #4108 of 4576
And theyre 175 watts instead of 50. 6.5" instead of 4". Im still looking for some good bookshelf speakers though. Seems like for $200 I should be able to find some really good bookshelves. Even if theyre used. My main concern is music. But its going to be difficult to find something to match acoustically with everything else being Klipsch.
post #4109 of 4576
Matching is overrated, especially on a budget. Center is PL-26,iIrc? What's the rest of your set-up & what are you aiming for?
Edited by SanchoPanza - 6/9/13 at 4:56pm
post #4110 of 4576
Looked, but could not find any. There is a replacement. FH-65B around $200 a pair on Amazon, see ad, bottom of this thread.
Edited by SanchoPanza - 6/9/13 at 5:22pm
  Back to Forum: Speakers
