I'm sort of limited by room set up, I'm in a 1200 cubic foot room and I've got a media cabinet and towers surrounding a Panasonic 58" plasma. I've got no room for speaker stands on either side of the towers so I must use bookshelves (RB61's) placed in the furniture surrounding the display and my center (RC10) is in a cabinet just under the display.
My question is, I've got a smaller center channel, the only one I can find to fit in my 6" space is the Klipsch RC-10, will replacing my bookshelves (RB61's) with the Klipsch THX Ultra2 KL-650's be too overwhelming for my little center channel?
The KL-650's will almost fit perfect in the towers, filling an entire shelf and offering a semi-custom look, also limiting the acoustic disadvantages of having the speaker on a shelf.
I suppose I could put the Left, Right and Center channel on the wall with the center above the display but there is an overhanging dropped ceiling which is bad for acoustics and I have no way of cleanly getting the speaker wire to the front 3 channels with them on the wall. Aesthetically it would be a disaster. So putting them on the wall is a last resort.
I just wonder if the KL-650's are too much and are going to make my system sound unbalanced with the RC-10 as my center....
By the way, the Surrounds are the Klipsch in walls R-5650S
thoughts/opinions???
