Originally Posted by
Lotzostuff
First, room set up and equipment:
Dimensions: 17' deep, 13' wide, 10' ceilings (perfect rectangle)
Projector: Acer H7531D DLP Home Theater Projector (1080P)
Receiver: Denon AVR-1507
Screen: TBD, thinking somewhere around 100"
Speakers: Have 1 7604 thus far to use as center, thinking of ordering 4/6 more (see below)
Room was prewired for 5.1 but I believe this receiver allows for 7.1 Need to read up and see if it would be worth running the extra speaker wire for the 2 additional channels.
The general concensus on the forums seems to be that the benefits of 7.1 over 5.1 are rather marginal - many "experts" seem to suggest spending more on upgrading 5.1 speakers over adding rear channels. There is a vocal minority, however, who do love the 7.1. I don't really have an opinion one way or the other since I've never had a 7.1 setup.
Lotzostuff
L/C/R are on front wall about 6 feet high. I am assuming I'll be happier with the sides being lower and the center getting lowered to just above or below my screen?
The usual advice is to place the LCR at about ear level if possible, so the answer to your question is probably yes.
Lotzostuff
Surround speakers are prewired for side walls about 6 feet high as well and approx 4 feet forward of the back wall. Can I make this location work or would I be happier with them in the ceiling or elsewhere?
That sounds just fine for the surrounds .... the usual advice is that they be placed a bit above ear level (say, 2 to 3 feet) and just behind the listener position ... they may be a foot or two high over optimum there, but I wouldn't worry about it at all.
Lotzostuff
I am planning on ordering at least one more pair of 7604s for right and left, but what is recommended for my rears? Seems like opinions on all of the other options are all relatively good. 7604s? 7605s? 4929s with angled woofer?
Most of the experts seem to recommend in-wall over in-ceiling, so if you go 7.1, I'd probably stick with an in-wall installation and use the 7604s. Personally, I don't think it matters that much though, especially for rears, and if for cosmetic reasons you wanted to do an in-ceiling installation, either of the in-ceilings should be fine. I have a pair of the 4929s installed in my kitchen ceiling for 2.0 music, and I think the angled woofer would work well for rears, pointed toward the listening position.
Lotzostuff
Can I use the old powered sub I got with a Sony HTIB set up for now?
Why not? If you don't like the way it sounds, then you can just upgrade whenever you want.
Lotzostuff
Thanks again to every person who has contributed to this valuable thread thus far, and thanks in advance to anyone who can provide me advice on my specific situation.
I'm not an expert, so take my advice with that in mind, but I have read quite a bit on the forums over the past 6 months, and I'm not bad at regurgitating what I've read.
