AVS › AVS Forum › Audio › Speakers › Monoprice in-wall, in-ceiling speakers
Monoprice in-wall, in-ceiling speakers - Page 60
post #1771 of 1791
Originally Posted by rogersmj View Post
Of the circular-shaped (ceiling) speakers, which ones are everyone's favorites for general music listening? Won't be cranked, just want quality background sound. I'm looking at the 6038 because they have the micro-flange and look nice, but I'm wondering if I should go for the 8" 4104s.
I have the 8" speakers and like them a lot. They provide plenty of bass when powered properly and have a smooth natural sound. I would go with 8" speakers unless you have a subwoofer. The extra two inches of speaker will give you a little bit deeper bass.
post #1772 of 1791
I agree. If you have a subwoofer go with the 6 1/2" speaker if you don't go with the 8". I've used both the micro-flange and older style monoprice speakers. The micro-flange were better, but not that much. It would be worth the extra effort to get the 4104s if you are not planning on using a subwoofer.
post #1773 of 1791
Thank you, based on this and Daniel's comments I'll probably go with the 8".
What do you mean, "powered properly"? What's the best way to figure out how to power a particular set of speakers? Will the popular AudioSource AMP 100 be sufficient, and how can I tell?
Please, teach me to fish...
post #1774 of 1791
Monoprice Price Alert:  6816's are now on Sale for $75.94 per pair. A daily deal from Facebook at 15% off. Shipping is ouch, anybody got a promo code?
Edited by B1ueleader - 3/21/14 at 11:46am
post #1775 of 1791
I am considering 7607's for front and rears in my bonus room. A 7604 for the center. I am a total noob but I want this room to immerse with quality sound for both music and HT. My room is 19 x 11. I am considering dennon avr-x2000 and uncertain about what sub. Help from any of you pros is much appreciated!!!
post #1776 of 1791
Hello I installed 12 of the 4103's (6.5' ceiling speaker) in my brand new house. I have to say these things sound pretty bad. I cant believe they have such good reviews. Can anyone recommend a replacement for these?eek.gif
post #1777 of 1791
A little more info is needed. What are you using to power them? What is the room(s) size? Is out for while home audio use for music or theater applications? Do you have, or plan on having a subwoofer?
post #1778 of 1791
im powering them with a yamaha rxv-675. This is in a pretty big living room/kitchen. about 15'x30' with 9' ceiling. hardwood floor everywhere. I am using an 18" uxl-18 in a sealed box. When I added the subwoofer the sound obviousely improved a lot but to me it just sound off. like there are frequencies missing or something
post #1779 of 1791
im powering them with a yamaha rxv-675. This is in a pretty big living room/kitchen. about 15'x30' with 9' ceiling. hardwood floor everywhere. I am using an 18" uxl-18 in a sealed box. When I added the subwoofer the sound obviously improved a lot but to me it just sound off. like there are frequencies missing or something
You are powering 12-speakers with a 7-channel amp. What are you using for impedance matching? Are you using volume controls on each zone? If so how do you have the impedance correction jumpers set up?
Also do you happen to have any Audesey settings in use on your Yamaha? I noticed when I first used the 7604s I had the equalizer setting on my receiver set to the audysey calibration from my old speakers and it sounded horrible. I turned of the equalizer it sounded better, then ran audysey and it was much better.
post #1780 of 1791
sorry. I have 2 systems that are 5.1 and a washroom with 2 speakers. So the the 5.1's have one yamaha amp each. No audesey on yamaha amps
post #1781 of 1791
Hi, I've never had a home theatre system, but will be putting 7.1 system into my new house.  I was attracted to the low price and positive reviews on these monoprice in-wall and ceiling speakers, and would like some advice/suggestions on my proposed setup.  My seating area is about 7.5 feet from the wall with the tv and lcr speakers, the surround speakers are even with the seating area on the left and right, and the surround back  about 2 feet behind the seating area on the ceiling.
6317 for the center channel
6816 for the front left/right and side surround left/right speakers
4929 for the surround back left/right
4928 for the sub w/an audiosource 100 amp/bridged to drive it.
I will use the Sony STR-DH740 as the receiver to drive everything.
Does this setup sound reasonable, am I making any obvious mistakes?
post #1782 of 1791
One idea may be to tweak the switch on the speaker that raises and lowers the treble for different wall and ceiling types.
Second idea would be to play with the listening modes such as 5.1, all channel stereo, etc. (equalizer settings too).
Third would be to investigate your sources. The six inch speakers should be crossed over at 80 Hz or higher. That will conserve valuable power from the AVR.
Are your sources 5.1, MP3s, Pandora?
post #1783 of 1791
I wouldn't waste my time with an in-wall subwoofer. The Monoprice Premium Subwoofer will outperform the 4928 in-wall at less money. If you have any extra money I'd suggest upgrading to a HSU or SVS subwoofer.
post #1784 of 1791
Agreed. Or if you want a lot of bang for your buck, check out the BIC F12 (on Amazon for about $200) -- that's probably what I'm going to get to go with my Monoprice in-walls.
post #1785 of 1791
I'll look into it.  My girlfriend doesn't want any visible speakers because it's such a small area.  She thinks we should just use the TV speakers or get a soundbar.  I've talked her into the in-wall option, I'll see how she feels about a subwoofer in the corner.
post #1786 of 1791
^^ have you considered a DIY sub?? I made mine into an oversized end table and my wife loves it. You could easily integrate a sub (or two) if you hide them as room decor.
post #1787 of 1791
New construction, out 2 months before low voltage wiring. I have ceiling speakers to purchase and looking at Monoprice. Here are the location; great room main (6), sunroom (2), front porch (2), gym (2), great room basement (4), basement patio covered (2). All will be used as background music, what recommendation would you give?
post #1788 of 1791
I always recommend the 8" models. They provide a fuller sound than the 6" versions.
8 Inches Kevlar In-Ceiling Speakers (Pair) - w/ 15 Degree Angled Woofer
8-inch Kevlar 2-Way In-Ceiling Speakers (Pair) - 80W Nominal, 160W Max
With either, you will be able to use a subwoofer to round out the bottom end.
post #1789 of 1791
Is the subwoofer a ceil speaker also?
post #1790 of 1791
They have "in wall" subwoofers, but I don't recommend this as an option unless you have to. A real subwoofer in the corner is always a better option for bass quality.
As far as placement is concerned, the in-wall subs can be put in a wall, floor, out ceiling. I would download the manual from the site and read up a little.
Those subs are also passive.
post #1791 of 1791
If there are 3-4 zones on the main and 2 in the basement, a sub is irrelevant except the one zone it's in? If these ceiling speakers are used for background vice TV watching, the sub is only used to round out?
  Back to Forum: Speakers
