AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › Help me choose please between these 2
post #1 of 3
is the HD-A30 a good enough 1080p player or should I got straight for the HD-A35
post #2 of 3
As far as video goes they are the same. For audio stepup go with the a35, it has analog outs and can bitstream the high def audio codecs also.
post #3 of 3
They are almost identical except for the extra audio features of the HD-A35. Unless you can take advantage of multichannel analog outputs or bitstream output of TrueHD and DTS-HD, the HD-A30 should be more than sufficient.
  Back to Forum: HD DVD Players
