I'm using BeyondTV has my PVR software. I'm currently using the Hauppauge remote receiver to control the app.
I want to instead use the builtin remote receiver of the case.
Here are my questions:
Thanks for any help!
Here's my setup:
Case: Zalman HD160XT-Black|PSU: Corsair CMPSU-520HX 520W|MB: Fatal1ty F-I90HD w/ HDMI|OS HD: Seagate 160GB EIDE (WinXPSP2)|Storage: WD 750GB (x4 RAID10)|CPU: Intel E6420 Core 2 Duo|CPU Cooler: Zalman CNPS7700-CU|Mem: 2GB TWIN2X1024-6400C4 PC2-6400|ODD: LH-20A1H-185 LITE-ON DVD R/W|Tuners (5OTA):(1) WINTV-HVR-1600 / (2) HDHomeRuns [8-way CVT-2/8PIA II]|Remotes: Harmony 659 & 880|KB: BTC 9019URF
- Do I have to use the zini software? I don't care or have a need for the "monitoring" screen that comes up with that software.
- Does the IR receiver also allow for waking up the machine from standby?
- Since the remote is MCE-compatible, will it also control BeyondTV?
- Once all that is resolved, will I be able to program my Harmony remotes instead of using the supplied Zalman remote?
Here's my setup:
