Hi all,
I wanted to ask if anybody has played around with the ethernet advanced settings (in 10.5)? I remember that jumbo packets have been mentioned a couple times on this board, but I don't wanna just play around with the network settings without knowing what's best.
Basically, I'm controlling my htpc-mini from a G5 using chicken of the vnc. Both machines run Leopard, and there's a netgear gs108 gigabit switch between the two.
The network advanced settings in both machines are as follows:
- configure: automatically
- speed: 1000baseT
- duplex: full duplex, flow control
- MTU: standard (1500)
Is there anyway I can increase speed when using VNC? It just seems kind of sluggish. When I'm copying big files between the computers I'm getting around 50-60MB/sec (which is around 400mbits if I do the calculation correctly). It could just be a tad faster, right?
Thanks in advance
- speed: 1000baseT
Thanks in advance
