First post here. I'm building a new house and setting up a home theater at the same time. I am pretty confused. I need to figure out which components I should buy (receiver, dvd/blue ray, ?)
Here is what I am having installed:
5.1 in-wall speakers:
Proficient Audio C870 ceiling mount speakers
Proficient Audio IW550 center channel
Proficient Audio S10 Subwoofer
Television will be a 1080p 50"-60" LCD or DLP (not sure yet)
It is not a theater room but a section of a very large rec room.
I also have a Nuvo 4 zone controller for whole house audio. I think the only way the receiver comes into play here would be as the AM/FM radio.
Where I get very confused is which receiver I need. I get confused with the 1080 switching, passthrough, etc.? I am spending several thousand dollars on the above mentioned setup, so I so want nice quality video and audio but I am not a die hard audio or videophile like some people. In other words, if spending $500 extra on something that only the keenest of ears or eyes would notice then it's not worth it. I do, however want to take advantage of a new HD TV and have an impressive home theater. I also want to future proof myself to some extent. Now that you have a better idea of where I'm coming from here is what I'm considering.
Receiver - leaning towards Onkyo or Yamaha based on advice, reviews, etc. thinking I need to spend $500-900 ish????????
DVD/CD - Thinking about Sony DVP-NC85H/B HDMI/CD Progressive Scan 5-Disc DVD Changer for use as my DVD player as well as CD player for whole house audio??????
Blue Ray - Will probably wait it out and maybe get one down the road unless you convice me that I need one now.
IPOD/MP3 - Do I need a $100 docking station or just a $10 cable that connects it to the receiver?????
Any advice would be appreciated. Thank you very much in advance for your time. I would also consider buying equipment from sources on this board.
Thank you,
Mike
Thank you,
Mike
