Originally Posted by
whipped424
well you're not supposed to get mode not supported on your tv. if this happens then samsung will update your receiver for you!
i'm supposed to get mine back on tuesday
what exactly are they going to do?
I bought my receiver (as720) at the beginning of July and started getting this issue 90% of the time when i switch from dvd playback to the xmb after about 2 weeks.
I removed the receiver from the equation and it works fine directly plugged into my Samsung 46" LCD 4669 model.
If others are having the same issue it makes me wonder if there is some issue with the passthrough for HDMI...when you say update do you mean they update the firmware on it or just provide you with an updated version?
what kind of time frame did they give you for sending it away and did they cover the cost of shipping? did you have to send the speakers too or just the receiver?
I bought mine at best buy and haven't contacted samsung yet as I wanted to research the issue first.
Otherwise it works perfectly fine...i can temporarily resolve the issue by switching the receiver off then on, but I prefer to just switch it from vcr mode back to hdmi and then it comes back to life guaranteed. it's a minor inconvenience but i'd rather it just be fixed...
