OK, totally green here. I will be buying a Blue Ray for my wife this month and will be adding it to my HT set up. My rack is 30' away from the projector. The pj is a Sony VPL-HS60. (only one HDMI input) I was planning to run a dedicated cable for the Blue Ray. I figured HDMI would be the way to go but am not sure. I was looking at Monoprice for the cable. I have read about the HDMI cables but am still a little confused. I assume a silver coated cable is better than a Tin coated one. AWG doesn't appear to be that important. Should I go with a 1.3 cable or will it make no difference with the Blue Ray? Would I be better off just using the S-Video for the Blue Ray freeing up the HDMI for the DVD? I know it's a lot of questions. Thanks in advance for any help and/or clarification.
Art
Art
