Originally Posted by
floepie
I guess my point is that I don't see a need for a DTS-Connect at all. If I want to play my music files, I wouldn't want any re-encoding or matrix (DTS:Neo) at all. If I play BD disc, I would rather have the "core" DTS, as you say, or the normal AC3 track played instead.
I'll put my comments on this down in the last section, since they relate.
floepie
And, I'm assuming that both music and vanilla AC3/DTS can be played over HDMI. Is that correct? If not, SPDIF is fine, too.
The HDMI specs have way more then enough bandwidth to do everything S/PDIF does and more. Of course in the 780G's implementation it is effectively S/PDIF over HDMI so the same restrictions/limitations apply, this isn't the case with other chipsets that can pass multi-channel PCM such as Intel's G35, the upcoming GeForce 8200 and (presumedly) Intel's upcoming G45.
floepie
ISo, what it would boil down to for me at least is having SPDIF pass-through always enabled, and DTS Connect always disabled so that I can enjoy the native sound format, seeing as how TrueHD and other higher quality audio is impossible, digitally speaking.
Yes but, you're missing something. When you use DTS Connect what you're getting is the lossless audio track that has been decoded by the player (i.e. PowerDVD Ultra) into PCM (which is raw uncompressed digital audio) for the PC to use, mix, etc. DTS Connect then takes this uncompressed audio and compresses it into 1.5Mbit/s DTS. So yes it's lossy. But it comes from a lossless source. You get a trickle down benefit of having the source being lossless data. Choosing the legacy DTS core or AC3 track doesn't. You are choosing to use a lossy version that has no headroom, no extra bitrate, etc. I would think that it is preferable to take the lossless (i.e. perfect) version and then compress it down a bit. Just like how resizing a high resolution image retains some of the detail of the source, or displaying 1080p Blu-ray content on a 720p TV still looks amazing. You're still getting the best you can at the source point, it's only at the transport (S/PDIF) point that this high resolution has to be compromised.
This, by the way, is how the set-top HD DVD players and many Blu-ray players behave when using S/PDIF. They have a Dolby or DTS licenced encoder to do what DTS Connect or Dolby Digital Live do on the PC.
Now as an aside, even the 'legacy' tracks on these disc sound pretty darn good. This is because they typically use the maximum bitrate the standard DTS (1.5Mbit) or Dolby Digital (640Kbit) codecs allow. Standard DVDs didn't. AC3 on DVD max'ed out at 448Kbit/sec, and DTS was typically only used at 768Kbit/sec on DVD. So they will still sound at a least somewhat noticeably better. Experts in the audio field agree with this (it was said by film sound professionals in the now dead Industry Insider's threads from the HDTV Software Media Discussion forum here on AVS).
