Same here. Plus HDDVR package gets you NFL Net. With the newer D* boxes, you can set them to "hide" the repeating SD signals when the HD version is running identical programming (ie - ESPN, Discovery, SciFi, local network stations, etc - overrides the SD version - SD doesn't show up at all on guide)
So the only NFL Net signal I ever receive is the HD version.
Only time the "hide SD" does not apply is when the HD version of a channel broadcasts different programming than it's SD counterpart (example: Food Network)
