AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › HTPC Gaming › Specs good enough for games?
post #1 of 25
different forum.
original thread
http://www.avsforum.com/avs-vb/showthread.php?t=993679
my computer's specs are
intel core2 CPU 2.00GHz
nvidia 7500LE
2GB of RAM
are the specs good enough to play Company of Heroes on fairly decent settings?
what is the PSU requirement for the nvidia 9600GT?(watts)
also if i do upgrade, do i just install the graphics card and install the software?
based on my pc specs, will the games run well with just the upgrade to the 9600GT? or do i have to upgrade my CPU and other stuff?
also my motherboard is the one with the Intel iP945P/G chipset made my Asus
can it support the graphics card?
post #2 of 25
Just download and play the demo to see how well it runs.
post #3 of 25
get the 9600. powersupply min 350w. suggest 450-500 as numbers are "fudged" a bit.
cpu is addequete relative to video card. They will both bottle neck near same times, Cpu will overclock very well if you have a good motherboard very easy to get min 2.4ghz... even eaisier to get higher overclock with good ram and aftermarket cooling.
post #4 of 25
so if i do get the 9600, it'll be all right?
would i be able to play company of heroes on high/max settings very well?
post #5 of 25
Look up the specs for the game. Usually there is listed the minimum computer requirements to run it and the recommended specs to run it at higher settings. See how your computer compares. Also do what dpe8598 said and get the demo for free and try it out.
I doubt the nvidia 7500LE will be enough graphics card to run it at higher settings.
post #6 of 25
Oops, think I posted a few minutes ago in your other thread.
Anyhow, http://en.wikipedia.org/wiki/Company_of_Heroes
post #7 of 25
i dont understand what recommended settings mean.
does it mean i can run the games on high settings or i will be able to run it well with low settings?
post #8 of 25
With recommended settings it means you should have a great experience playing the game (with the specs stated) . minimum settings are the ones where low would be about all your gonna get.
post #9 of 25
so does recommended settings mean i can run it well on high settings or it'll run smooth on low/medium settings?
and on minimun requirements it'll be able to run on low and it'll be choppy?
also if i do upgrade, will it run very well on high/max settings?
(also high with games like crysis, world in conflict etc.?)
i dont understand about gaming resolutions. if i run it (theoratically) at 1980 x 1080, doesnt my monitor have to support that resolution to run it?
post #10 of 25
also do most new games support 16:10 resolutions? (hopefully including Company of Heroes)
post #11 of 25
with recommended in my experience, you may not be able to max everything out but everything should be fairly smooth on high (though you may have to tweak)
and no you will not be able to run crysis very well at high/max with the resolution of 1980x1080.
Right now I have a 24' lcd (res 1920x1200) and 2 8800gts 512's both oc'd to ssc speeds and although you can run crysis on very high It's still alot better on high because it's a very demanding game. You would have to do alot to your system to get crysis on high.
The higher your resolution the more your gonna have to turn down the goodies. at my res on very high the fps can dip in the low 20's and even the teens on crazy parts. although I don't really play crysis,I'm more of a COD4 kinda guy. (and it runs fine at max everything)
although I can't speak for Company of heroes, almost all my new games support the higher resolutions (crysis, COD4, orange box, UT3, bioshock) though there is a few you still have to hack to get it to run properly.
post #12 of 25
ok so because my monitor's native resolution is 1680 x 1050 i should stick to that
about the crysis thing i was just using that as a reference because thats the most demanding game i know and just wanted to know how the 9600 compared.
i'll just be happy if i can some fairly new games on high/max if i get the 9600
post #13 of 25
another quick question:
who are the best manufacturers with the best price when it comes to nvidia cards?
i also want to know if i'll be able to run Company of Heroes on high/max if i get the 9600
i dont think i can get the 8800 because it is a little out of my price range and i dont think there is room for a card that takes up two slots.
post #14 of 25
i also saw the sticky thread on this forum
Company of Heroes can run widescreen but Brothers in Arms: Road to Hill 30 can't.
instead of hacking, are there patches available that allow it to be run widescreen?
i dont want to mess with the settings that much like that.
post #15 of 25
also if i do get the 9600, how much would there be an increase in performance?
50% etc.
post #16 of 25
also im having trouble finding info on my motherboard just that it has that chipset and is made my asus. does it support PCI Express 2.0?
post #17 of 25
i think i found the motherboard but i dont think it has PCI Express 2.0, only x16
does this mean i cant upgrade to the 9600?
post #18 of 25
The 8800 doesn't take up two slots, it can be had for $235 now. Be a better choice.
PCI express 2.0 is meaningless. Don't worry about it.
post #19 of 25
so the 8800 will be better in performance than the 9600?
if i do upgrade, how much better will my overall performance be?
also there are alot of 8800's; which is the best? GTS, GTX etc for the best price?
post #20 of 25
I recommend an EVGA 8800GTS 512. It has the performance of a GTX (in some cases beats the GTX) for around $260. It also runs cooler than the 8800GT which allows for more overclocking. If you don't need the absolute best of the best the GT will definitely get the job done as it can keep up with the GTS in a lot of benchmarks. it can be had for around $220 or so. Either card offers tremendous bang for the buck.
Go ahead and google some GPU benchmarks and see if the GTS is worth it to you or maybe the GT is even more than you need in which case look for an ATI 3850, which are also a great bang for the buck.
8800GTS>3870~8800GT>3850
post #21 of 25
ok so i'll go for the 8800. can we expect a major price drop once the 9 series comes out?
however, im reluctant to upgrade unless i get a significant performance boost. will i get that with the upgrade to the 8800 more than i would if i upgraded to the 9600?
also, what are the PSU requirements for the 8800?
post #22 of 25
im thinking of getting a 8800GT.
http://www.newegg.com/Product/Produc...82E16814130318
I dont plan on playing games like crysis (im more of a console gamer) but i want to play some fairly new games on high
Company of Heroes and World in Conflict are probably the games i will play and maybe Starcraft 2 when it comes out. is the 8800GT enough to play these games on high/max? and is it better than the 9600GT?
another reason i chose to go with the 8800GT was because i saw the back of my computer and i dont have room for a double slot card...its a small motherboard/computer the one smaller than a mid-tower but not those tiny cube ones. the hp pavillion computer.
unless, does the extra slot go down or up from the slot where it is actually plugged in?
on top of it i have room but right underneath i have all those motherboard inputs and stuff.
post #23 of 25
Not really. Esp at higher rez's. The GTS 512 is almost the as good as the GTX but not at higher rez's. The 8800 GTS 512 is prob the best buy right now. For HTPC uses the GTS is better then the GTX. But for gaming the GTX/Ultra's are still top of the Nvidia food chain for now. But is worth the extra over the GTS...IMO....no.
post #24 of 25
It is true the GTX holds the crown in the High rez arena (but just barely), however, the extra price DEFINITELY does not match extra performance. We agree the GTS is the way to go...
GTX GTS benchmark summary from Tom's Hardware -These are numbers from an unoverclocked GTS too.
post #25 of 25
Nobody has mentioned this...but you really should overclock your processor. At 2ghz, you won't be getting the full benefit of an 8800GT because the CPU can't keep up with what the card is throwing at it. You should be able to get a 20% overclock = 2.4ghz without breaking a sweat...and if you have a decent motherboard, 2.8-3ghz isn't out of the question.
here are some guides..take an hour and learn how to OC. You'll be glad you did.
http://www.ocforums.com/showthread.php?t=515316
http://www.overclockersclub.com/pages/overclock_faq/
http://forums.extremeoverclocking.co...ad.php?t=79266
  Back to Forum: HTPC Gaming
